HOW TO
The Reclassify tool available with the Spatial Analyst license is used to add or change range values in a raster feature. However, it does not honor any custom or specified symbology applied to the original raster. This is by design, as the Reclassify tool changes the value of the newly added range outside of the original symbology.
When the Reclassify tool is used in a model, the original symbology applied can be retained by adding the Apply Symbology From Layer tool to the model. The same symbology layer can be used even when multiple raster outputs are involved in the model to automate the process within the same model.
This article describes how to use ModelBuilder to retain the raster symbology after using the Reclassify tool in ArcGIS Pro. The image below shows the differences in the symbology after using the Reclassify tool.
The following image shows the symbology layers are retained after running ModelBuilder.
Article ID: 000027041
Get help from ArcGIS experts
Download the Esri Support App
