HOW TO
Retain attribute domains during export
Summary
During data export, attribute domains are lost when exporting to shapefile or feature class format. This procedure describes the process of exporting the data as an XML workspace or recordset document, which allows the attribute domains to be retained throughout the export process.
This article applies to retired ArcGIS version 10.0. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Procedure
Follow these steps to export data as an XML Workspace document.
  1. In the Catalog window or ArcCatalog, right-click the table, feature class, feature dataset, or geodatabase to be exported, and click Export > XML Workspace Document.
Fully expand the geodatabase, etc. to be exported if the XML Workspace Document option is not activated.
  1. To export a blank schema, click Schema Only and designate the name and workspace for the output. If the metadata is to be included, ensure that Export Metadata is checked.
  2. Click Next to review the structure of the exported schema. Uncheck boxes of feature classes, tables, or relationship classes to be excluded from the export.
  3. Click Summary to review the contents of the export.
  4. Click Finish to complete the export process.
Article ID:000011499
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
