Summary
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
Instructions provided list the response to crashing and crash dumps.
Procedure
- Soft Crashes
Locate the crash dump here: (Windows 7/2008 Server) C:\Users\<username>\AppData\Roaming\ESRI\ErrorReports (XP/2003 Server) C:\Documents and Settings\<User Name>\Application Data\ESRI\ErrorReports
Go to the Doctor site.
Upload the Crash Dump.
Every Crash Dump has a CR Number.
If a CR has been exported to Nimbus, this can be seen from the Doctor page linked to QA Monitor.
[edit] Further Reading
http://blogs.esri.com/support/blogs/supportcenter/archive/2010/02/11/arcmap-crashed-send-us-your-report.aspx
- Hard Crashes (or Crashes to which a Crash Dump isn't Useful)
Hard crashes are ArcGIS Desktop software crashes that occur at a level below the ArcGIS Software itself. Rarely are these issues a problem with ArcGIS Desktop but instead a problem with OS (Operating System), Hardware, Registry Corruption, etc.
[edit] How to Support a Hard Crash
If a customer reports a Hard Crash, one that does not generate a crash dump (above), the first step is to try to reproduce the crash in house using the same data and/or workflow. If the issue is reproducible in house, a bug should be logged against the specific dataset or workflow that causes the hard crash.
If the hard crash cannot be reproduced, the issue is at a level far below the ArcGIS Software stack. The best advice Esri can offer in these cases is (in order of severity):
Try an Administrator Level Account
Try a Local Windows Profile Account
Repair the ArcGIS Software
Re-install the ArcGIS Software
Re-install the .NET Framework (version applicable to product such as 3.5.1 for ArcGIS Desktop 10)
Re-install MSXML 4
Seek help from IT department
Consider re-imaging the machine
Consider replacing the machine
