HOW TO
Represent data in non-spatial tables on the map in ArcGIS Pro
Last Published: May 3, 2022
Summary
Non-spatial tables (standalone tables) are used to store additional data that is related to spatial features. This data can be related to a spatial feature class such as counties, states, cities, and so forth. This article describes the steps to represent certain criteria or attributes based on a non-spatial table on the map in ArcGIS Pro.
Procedure
  1. In an ArcGIS Pro project, add the non-spatial table and the feature class related to the data in the table. For example, add the States feature class and the non-spatial table containing information on states.
  2. Relate the feature class to the non-spatial table with a one-to-many relationship.
    1. In the Contents pane, right-click the non-spatial table, and click Joins and Relates > Add Relate.
    2. In the Add Relate pane, ensure the non-spatial table is selected for Layer Name or Table View.
    3. Select the feature class for Relate Table.
    4. Select the fields for Input Relate Field and Output Relate Field.
    5. For Cardinality, select One to many. Click OK. These options are shown in the following image.
The Add Relate tool is used to relate the feature class to the non-spatial table.
  1. Right-click the non-spatial table in the Contents pane, and click Open. Click the Table Options menu The Table Options menu., and activate the Select related records option, as shown below.
  1. In the non-spatial table, select one or more rows. The map highlights features that are related to the selected rows.
The image below shows the corresponding related features are displayed and highlighted in the map based on a certain selection from the non-spatial table. In this example, four features are selected in the non-spatial table, and the corresponding features are highlighted in the map.
The selected rows from the non-spatial table is reflected on the related feature class features and highlighted on the map.
  1. Optionally, create a new layer based on the selection using one of the methods below:
    • Right-click the feature class containing the selected feature, click Selection > Make Layer From Selected Features. This method creates a new layer on-the-fly in the Contents pane.
    • Use the Copy Features tool to export the selected features and create a new feature class.
This process can be automated using ModelBuilder from the start, using the geoprocessing tools below:
  • Add Relate tool
  • Select Layer by Attribute tool
  • Copy Features tool
Re-configure the following tools in the geoprocessing model to repeat the workflow based on another selection:
The ModelBuilder geoprocessing model containing the tools to run the whole workflow.
Article ID: 000023150
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
