HOW TO
Instructions provided describe how to obtain the spatial relation between two objects using SQL in Oracle and st_geometry attributes. The output from the query reports the total number of objects that are interior, boundary, and exterior between two shapes being compared.
Code:
SQL> SELECT COUNT(*) cnt, relation
2 FROM (SELECT CASE WHEN sde.st_relate(a.shape, b.shape, 'T********') = 1 THEN 'Interior'
3 WHEN sde.st_relate(a.shape, b.shape, '********T') = 1 THEN 'Exterior'
4 WHEN sde.st_relate(a.shape, b.shape, '****T****') = 1 THEN 'Boundary'
5 ELSE 'Unknown'
6 END "RELATION"
7 FROM point_events a, poly_events b
8 WHERE b.event_name = 'STORM 129'
9 AND sde.st_envintersects(a.shape, b.shape) = 1)
10 GROUP BY relation
11 ORDER BY cnt;
CNT RELATION
144 Exterior
137 Interior
2 Boundary
Code:
2 FROM (SELECT /*+ NO_INDEX(a point_events_shape_idx) */ CASE WHEN sde.st_relate(a.shape, b.shape, 'T********') = 1 THEN 'Interior'
5 ELSE 'Unknown'
6 END "RELATION"
11 ORDER BY cnt;
CNT RELATION
5692 Exterior
137 Interior
2 Boundary
Because the point_events spatial index is not the access path, all point_event geometries are compared, and the number of geometries that are exterior to the input polygon increases (the number of interior and boundary point_events will be the same).
Article ID:000010364
Get help from ArcGIS experts
Download the Esri Support App
