HOW TO
Report geodatabase versioning statistics in an Oracle geodatabase
Summary
Instructions provided describe how to report geodatabase versioning statistics in an Oracle geodatabase. The SQL script provided below reports information about a versioned geodatabase in Oracle. The output lists the number of versions, the number of versions blocking the DEFAULT version from being compressed to state 0 and the owner.names of the first 5 blocking versions, the number of states, the number of entries in the state_lineages table, and the number of rows in the versioned table and delta tables.
Procedure
In SQL*Plus, connect as the sde user and execute the following SQL:
Code:
SET SERVEROUTPUT ON
DECLARE
TYPE cv_type IS REF CURSOR;
cv cv_type;
TYPE block_states IS TABLE OF INTEGER INDEX BY BINARY_INTEGER;
blocking_list block_states;
TYPE block_versions IS TABLE OF VARCHAR2(128);
blocking_ver block_versions := block_versions();
CURSOR tableinfo_cursor IS
SELECT owner,table_name,registration_id
FROM sde.table_registry
WHERE BITAND(sde.table_registry.object_flags,8) = 8
ORDER BY registration_id;
CURSOR ver_list IS
SELECT DISTINCT state_id
FROM sde.versions
WHERE name <> 'DEFAULT' AND owner <> 'SDE'
ORDER BY state_id;
compress_date DATE;
delta_table CHAR(1);
row_count NUMBER;
base_count NUMBER;
stmt VARCHAR2(2048);
state_id NUMBER;
lin_name NUMBER;
source_lin NUMBER;
com_anc_id NUMBER;
ver_blocking NUMBER DEFAULT 0;
cur_max_state NUMBER;
pos NUMBER;
idx INTEGER DEFAULT 1;
s1 NUMBER DEFAULT 0;
s2 NUMBER DEFAULT 0;
s3 NUMBER DEFAULT 0;
s4 NUMBER DEFAULT 0;
s5 NUMBER DEFAULT 0;
BEGIN
SELECT state_id, lineage_name INTO state_id, lin_name FROM sde.states
WHERE state_id = (SELECT state_id FROM sde.versions WHERE name = 'DEFAULT' AND owner = 'SDE');
SELECT COUNT(*) INTO row_count FROM sde.versions;
DBMS_OUTPUT.PUT_LINE(chr(10));
DBMS_OUTPUT.PUT_LINE(chr(160)||' Versioning statistics');
DBMS_OUTPUT.PUT_LINE(chr(160)||'=======================================================');
DBMS_OUTPUT.PUT_LINE(chr(160)||' Number of versions: '||row_count);
cur_max_state := state_id;
FOR ver_info IN ver_list LOOP
SELECT lineage_name INTO source_lin FROM sde.states WHERE state_id = ver_info.state_id;
SELECT MAX(lineage_id) INTO com_anc_id FROM
(SELECT lineage_id FROM sde.state_lineages WHERE lineage_name = lin_name AND lineage_id <= state_id
INTERSECT
SELECT lineage_id FROM sde.state_lineages WHERE lineage_name = source_lin AND lineage_id <= ver_info.state_id);
IF com_anc_id < state_id THEN
ver_blocking := ver_blocking + 1;
IF com_anc_id < cur_max_state THEN
IF blocking_list.COUNT < 5 AND blocking_list.EXISTS(com_anc_id) = FALSE THEN
blocking_list(com_anc_id) := com_anc_id;
ELSE
IF blocking_list.COUNT = 5 AND blocking_list.EXISTS(com_anc_id) = FALSE THEN
pos := blocking_list.FIRST;
WHILE pos IS NOT NULL LOOP
IF blocking_list(pos) = com_anc_id THEN
blocking_list.DELETE(pos);
cur_max_state := com_anc_id;
EXIT;
END IF;
pos := blocking_list.NEXT(pos);
END LOOP;
END IF;
END IF;
END IF;
END IF;
END LOOP;
DBMS_OUTPUT.PUT_LINE(chr(160)||' Number of versions blocking DEFAULT: '||ver_blocking);
IF ver_blocking > 0 THEN
DBMS_OUTPUT.PUT_LINE(chr(160)||' Top '||blocking_list.COUNT||' blocking versions...');
CASE
WHEN idx = 1 THEN s1 := blocking_list(pos);
WHEN idx = 2 THEN s2 := blocking_list(pos);
WHEN idx = 3 THEN s3 := blocking_list(pos);
WHEN idx = 4 THEN s4 := blocking_list(pos);
WHEN idx = 5 THEN s5 := blocking_list(pos);
END CASE;
idx := idx + 1;
END LOOP;
stmt := 'SELECT name FROM
(SELECT owner||''.''||name name FROM sde.versions
WHERE state_id IN
(SELECT DISTINCT lineage_id FROM sde.state_lineages
WHERE lineage_name IN
(SELECT DISTINCT lineage_name FROM sde.state_lineages
WHERE lineage_id IN (:state1,:state2,:state3,:state4,:state5)))
ORDER BY state_id) vers
WHERE rownum < 6';
EXECUTE IMMEDIATE stmt BULK COLLECT INTO blocking_ver USING s1, s2, s3, s4, s5;
FOR i IN 1..blocking_ver.COUNT LOOP
DBMS_OUTPUT.PUT_LINE(chr(160)||' '||blocking_ver(i));
END LOOP;
END IF;
SELECT COUNT(*) INTO row_count FROM sde.states;
DBMS_OUTPUT.PUT_LINE(chr(160)||' Number of states: '||row_count);
SELECT COUNT(*) INTO row_count FROM sde.state_lineages;
DBMS_OUTPUT.PUT_LINE(chr(160)||' Number of state lineages: '||row_count);
SELECT COUNT(*) INTO row_count FROM sde.state_lineages WHERE lineage_name = lin_name AND lineage_id <= state_id;
DBMS_OUTPUT.PUT_LINE(chr(160)||' DEFAULT versions lineage length: '||row_count);
SELECT MAX(compress_start) INTO compress_date FROM sde.compress_log;
DBMS_OUTPUT.PUT_LINE(chr(160)||' Last compress: '||to_char(compress_date, 'MON-DD-YYYY'));
FOR table_info IN tableinfo_cursor LOOP
stmt := 'SELECT COUNT(*) FROM '||table_info.owner||'.'||table_info.table_name;
OPEN cv FOR stmt;
LOOP
FETCH cv INTO base_count;
EXIT WHEN cv%notfound;
END LOOP;
CLOSE cv;
FOR i IN 1..2 LOOP
IF i = 1 THEN
delta_table := 'a';
ELSE
delta_table := 'd';
END IF;
stmt := 'SELECT COUNT(*) FROM '||table_info.owner||'.'||delta_table||''||table_info.registration_id;
OPEN cv FOR stmt;
LOOP
FETCH cv INTO row_count;
END LOOP;
CLOSE cv;
IF i = 1 THEN
DBMS_OUTPUT.PUT_LINE(chr(160)||' Table - '||table_info.owner||'.'||table_info.table_name||' ('||table_info.registration_id||')');
DBMS_OUTPUT.PUT_LINE(chr(160)||' -- Base table: '||base_count);
DBMS_OUTPUT.PUT_LINE(chr(160)||' -- Adds table: '||row_count);
IF row_count > 0 THEN
stmt := 'SELECT ROUND(COUNT(*)/'||row_count||' * 100, 2)
FROM '||table_info.owner||'.a'||table_info.registration_id||'
WHERE sde_state_id IN (SELECT lineage_id
WHERE lineage_name = '||lin_name||' AND lineage_id <= '||state_id||')';
EXECUTE IMMEDIATE stmt INTO row_count;
DBMS_OUTPUT.PUT_LINE(chr(160)||' -- Percentage rows in the DEFAULT version lineage: '||row_count||'%');
END IF;
ELSE
DBMS_OUTPUT.PUT_LINE(chr(160)||' -- Deletes table: '||row_count);
FROM '||table_info.owner||'.d'||table_info.registration_id||'
WHERE deleted_at IN (SELECT lineage_id
END IF;
END IF;
END LOOP;
END LOOP;
END;
  • Example output:
    Code:
    � Versioning statistics
    �Number of versions: 7248
    �Number of versions blocking DEFAULT: 168
    � Top 5 blocking versions...
    � RANDY.REV_6847258
    � CHRIS.REV_7019237
    � CLARE.REV_7069544
    � LUCY.REV_7043793
    � SUSAN.REV_7069206
    �Number of states: 8371
    �Number of state lineages: 1804258
    �DEFAULT versions lineage length: 521
    �Last compress: SEP-21-2008
    �Table - ADMIN.PRIMARYCONDUCTOR (148)
    � -- Base table: 440065
    � -- Adds table: 15156
    � -- Percentage rows in the DEFAULT version lineage: 21.64%
    � -- Deletes table: 6056
    � -- Percentage rows in the DEFAULT version lineage: 34.79%
    �Table - ADMIN.BUILDING (338)
    � -- Base table: 58955
    � -- Adds table: 524
    � -- Percentage rows in the DEFAULT version lineage: 68.7%
    � -- Deletes table: 400
    � -- Percentage rows in the DEFAULT version lineage: 61%
Article ID:000010358
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
