HOW TO
Replace layers that source data from a local disk with feature service layers
Summary
It is not possible to directly replace layers that source data from a local disk with a feature service layer. However, it is possible to recreate the layer as a feature service layer into a map document and insert the new layer into the map document using the arcpy.mapping method, InsertLayer(). The old layer can be removed by using the RemoveLayer() method.
Procedure
The following code sample demonstrates how to replace layers by iterating through the list of layers in a map document (mxd), using the InsertLayer() method to insert the designated layers and remove the desired layers using the RemoveLayer() method.
  1. Iterate through layers that reference feature services in a map document and save to layer files using the SaveToLayerFile method:
Import arcpy
#Set the workspace to the desired output layer files.
arcpy.env.workspace = r"D:\Cases\01800498_SourceFeatureService"
#Specify the desired map document.
mxd = arcpy.mapping.MapDocument("CURRENT")
#Create a Python list of layers in the mxd
layers = arcpy.mapping.ListLayers(mxd)
#Iterate through the layer list and create a layer file for each layer in the list.
for layer in layers:
    arcpy.SaveToLayerFile_management(layer,  layer.name)
  1. Create a list of available feature service layer files. The list can be created from the variable created in step 1, layers.
serviceList = []
    serviceList.append(layer.name)
  1. Iterate between the list, and replace the layers using the InsertLayer() and RemoveLayer() methods.
    if layer.name in serviceList:
        serviceLayer = arcpy.mapping.Layer(ws + "\\" + layer.name + ".lyr")
        arcpy.mapping.InsertLayer(df, layer, serviceLayer, "AFTER")
        arcpy.mapping.RemoveLayer(df, layer)
Article ID:000013565
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
