HOW TO
Repair automatically recreated geodatabases in ArcGIS Pro and prevent reoccurrence
First Published: July 21, 2026
Last Published: September 10, 2026
Summary
In ArcGIS Pro 3.6 and later, deleting, renaming, or moving a default geodatabase associated with a project, or making it inaccessible outside ArcGIS Pro, causes ArcGIS Pro to automatically create a new default geodatabase when the project is reopened.
This behavior can result in unnecessary geodatabases, and the workflow provided below repairs and prevents these geodatabases from being recreated.
The dialog box returned when a geodatabase is inaccessible in ArcGIS Pro
Procedure
  1. Open the project in ArcGIS Pro.
  2. Click Project > Options.
  3. In the Options dialog box, click General.
  4. Click Repair Project Items to open the drop-down list.
  5. Under Default Geodatabase Handling, select Prompt to specify a different geodatabase.
  6. Click OK.
The Options dialog box in ArcGIS Pro
  1. In the Catalog pane, click Databases to open the drop down-list.
  2. Right-click the geodatabase and select Show In File Explorer.
  3. In the Windows File Explorer window, delete the recently created geodatabase folder.
  4. Close and re-open the ArcGIS Pro project.
  5. When prompted with the Project Item Repair dialog box, click the Select Default Geodatabase The Select Default Geodatabase button button to browse and select an existing geodatabase or create a new one in a specific location.
The Project Item Repair dialog box in ArcGIS Pro
Article ID: 000041714
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
