HOW TO
Rename the symbology title in the map legend of a clustered layer in ArcGIS Online Map Viewer
First Published: September 13, 2022
Last Published: September 13, 2022
Summary
In ArcGIS Online Map Viewer, when a map has a layer with many point features, clustering can be enabled to group the point features that are near to one another into a single symbol. The map legend then shows the symbology title, patch, and labels of the clustered point features.
By default, when clustering is enabled on a point layer, the legend's symbology title is 'Number of features' as shown in the image below.
The Legend has 'Number of features' description by default
This article describes how to rename the symbology title of a clustered layer's legend in ArcGIS Online Map Viewer.
Procedure
  1. Open the map containing the point layer in Map Viewer.
  2. Navigate to the point layer and enable clustering. Refer to ArcGIS Online: Configure clustering (Map Viewer) for instructions.
  3. Click Cluster fields. The Fields window is displayed.
Click 'Cluster fields' in the Clustering window
  1. Select the field to rename. The Formatting window is displayed.
The field of the point layer
  1. In the Display name text box, specify a name for the field's display name.
  2. Click Done.
Configure the Formatting window
  1. On the Contents (Dark) toolbar, click Save and open > Save.
The image below shows the legend's symbology title is renamed.
The legend's display name is now renamed
Article ID: 000028268
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
