HOW TO
Rename the ST_Geometry points' Oracle LOB segment
Summary
Instructions provided describe how to rename the ST_Geometry points' LOB segment.
If the LOB segment name is not specified during the creation of the ST_Geometry attribute, the LOB segment name is created automatically by Oracle. Without an identifiable name, it may be difficult to identify which LOB segments are impacted by performance. By providing a LOB segment name, the user controls the naming convention and can specify a name that relates to the table name.
Procedure
  1. Use Oracle's ALTER TABLE command the to rename a LOB segment.
    Code:
    SQL> ALTER TABLE streets
    2 MOVE LOB(shape.points) STORE AS streets_lob_seg;
    Table altered.
    When Oracle moves the physical storage of the LOB segment and table, all existing indexes are marked as unusable.
    Code:
    SQL> SELECT index_name, status
    2 FROM user_indexes
    3 WHERE table_name = 'STREETS';
    INDEX_NAME STATUS
    STREET_NAME_IDX UNUSABLE
    R45_SDE_ROWID_UK UNUSABLE
    SYS_IL0000346092C00038$$ VALID
    A9_IX1 UNUSABLE
  2. Each index must be rebuilt so that it is valid. Enter the code below to alter the index:
    Code:
    SQL> ALTER INDEX street_name_idx REBUILD;
  3. Optional: Gather new table statistics.
    See Oracle's documentation for additional information.
Article ID:000009516
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
