HOW TO
Rename the Map Viewer default New Feature title in the Enterprise portal and ArcGIS Online
Last Published: February 21, 2025
Summary
In Map Viewer in the ArcGIS Enterprise portal and ArcGIS Online, a default title is assigned when a new hosted feature layer is created without specifying a field. This default behavior ensures consistent labeling for new features but requires manual renaming for clarity in specific workflows. The 'Create features' section in the Editor pane displays this title as 'New Feature', as shown in the image below.
The default title of the 'Create features' section in the Editor pane displays as New Feature
This article provides two workflows to rename the default New Feature title in the ArcGIS Enterprise portal and ArcGIS Online.
Procedure
Rename the default new feature in Map Viewer Classic
  1. Refer to Steps 1 through 6 in Portal for ArcGIS: Create feature templates in Map Viewer Classic or ArcGIS Online: Create feature templates in Map Viewer Classic for instructions to open the hosted feature layer in Map Viewer Classic.
  2. In the Manage New Features pane, for the feature template, click the drop-down button and select Properties.
The Manage New Features pane
  1. In the Properties window, rename the feature template in the Name: section. In this example, the name is 'Houses in Mississippi'.
  2. Click DONE.
The Properties window
  1. In the Manage New Features pane, click SAVE CHANGES.
The SAVE CHANGES button in the Manage New Features pane
  1. Refresh the web map and observe the edits are reflected.
Map Viewer Classic will be retired in 2025 in both the ArcGIS Enterprise portal and ArcGIS Online. Refer to Deprecation: Map Viewer Classic Deprecation for more information.
Rename the default new feature in the ArcGIS Field Maps Designer web app
  1. Navigate to ArcGIS Field Maps Designer from ArcGIS Online or ArcGIS Enterprise portal.
  2. Refer to Steps 1 through 3 in ArcGIS Field Maps: Update the name and description to rename the default new feature.
  3. Refresh the web map and observe the change reflected.
The image below shows the default new feature is renamed Houses in Mississippi in the ArcGIS Enterprise portal and ArcGIS Online Map Viewer.
The default new feature is renamed in ArcGIS Online and the ArcGIS Enterprise portal Map Viewer
Article ID: 000034643
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise 11 3
  • ArcGIS Enterprise 11 2
  • ArcGIS Enterprise 11 4
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
