HOW TO
Remove the symbology heading in ArcMap and ArcGIS Pro
First Published: July 17, 2020
Last Published: July 19, 2023
Summary
When multiple symbols are used to represent features in a single layer, the field used to classify the features is automatically added above the legend as a heading. Sometimes, the heading is not required and may be removed as the symbology provides adequate information.
Procedure
Follow the instructions below to remove the symbology heading in ArcMap and ArcGIS Pro.
The following workflow applies to all symbology types in ArcMap, and only to unique value symbology in ArcGIS Pro. For more information, refer to BUG-000140094.
ArcMap
  1. In the Table of Contents window in ArcMap, navigate to the preferred symbology heading. In this example, the symbology heading used is Shape_Area.
The Table of Contents window in ArcMap.
  1. Double-click the symbology heading, and press Delete to delete the heading.
The Table of Contents window to Delete the heading
ArcGIS Pro
  1. In the Contents window in ArcGIS Pro, navigate to the preferred symbology heading. In this example, the symbology heading used is Shape_Area.
The Contents window in ArcGIS Pro.
The Contents window to Delete the heading
Article ID: 000023434
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
