HOW TO
Remove dates before current date in an attribute table using Arcade in Portal for ArcGIS and ArcGIS Online
Last Published: May 9, 2024
Summary
In an attribute table containing a date field for a feature layer in Portal for ArcGIS and ArcGIS Online, removing expired dates from today's date is important for data accuracy as inconsistencies can lead to errors.
This article describes the workflow to remove dates before the current date in an attribute table using an Arcade expression in Portal for ArcGIS and ArcGIS Online.
In this example, the attribute table contains invalid dates considering today's date is January 26, 2024.
The attribute table contains invalid dates
Procedure
  1. Log in to Portal for ArcGIS or ArcGIS Online and click Content > My Content.
  2. Click the hosted feature layer containing the date field to open the item details page.
  3. Calculate the field to remove invalid dates using Arcade. In this example, the 'Expired' field is selected. Refer to Portal for ArcGIS: Calculate values for a field or ArcGIS Online: Calculate values for a field for instructions.
  4. In the Expression window, specify the following Arcade expression:
    1. Get the current date and time.
var today = Now();
  1. Retrieve the value of the date field from the attribute table.
var expirationDate = $feature['Expired'];
  1. Check and delete if the expiration date is before today's date.
if (expirationDate < today) {
    return null;
} else {
    return expirationDate;
The code block below shows the full working script.
var today = Now();
var expirationDate = $feature['Your_Date_Field'];
    return null;
} else {
  1. Click OK.
The image below shows the attribute table after removing the invalid dates.
The invalid dates are removed
Article ID: 000032562
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
  • ArcGIS Enterprise 11 3
  • ArcGIS Enterprise 11 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
