HOW TO
Remove cross-edged polygons using ArcPy in ArcGIS Pro
First Published: May 20, 2026
Last Published: May 20, 2026
Summary
In ArcGIS Pro, ArcPy can be used to selectively remove cross-edged polygons while preserving the remaining polygon geometry. Using ArcPy avoids unintended removal of polygon areas.
Procedure
  1. In ArcGIS Pro, on the View ribbon tab, in the Windows group, click Python Window.
  2. In the Python window, copy and paste the code below to remove the cross-edged polygons using ArcPy.
    1. Import the ArcPy library and Python's itertools module.
from itertools import combinations
import arcpy
  1. Define the feature layer.
polygon_fc = "TEST_POLYGONS"
  1. Create a copy of the feature layer.
arcpy.management.CopyFeatures(polygon_fc, "edited_polygon")
  1. Initialize counters.
overlap_count = 0
edited_polygon_count = 0
  1. Retrieve object IDs and polygon geometries.
polygon_dict = {
    row[0]: row[1]
    for row in arcpy.da.SearchCursor("edited_polygon", ["OID@", "SHAPE@"])
  1. Perform pairwise comparisons of the polygons from the feature layer.
for oid1, oid2 in combinations(polygon_dict, 2):
    polygon1 = polygon_dict[oid1]
    polygon2 = polygon_dict[oid2]
  1. Check for polygons with no intersection.
if polygon1.disjoint(polygon2):
        continue
  1. Check for polygon containments.
if polygon1.contains(polygon2) or polygon1.within(polygon2):
        continue
  1. Identify cross-edged areas.
intersect_polygon = polygon1.intersect(polygon2, 4)
    if intersect_polygon.getArea() <= 0:
        continue
    overlap_count += 1
  1. Remove the cross-edged areas from the polygon.
if polygon1.getArea() > polygon2.getArea():
        with arcpy.da.UpdateCursor(
            "edited_polygon", ["SHAPE@"], f"OBJECTID = {oid2}"
        ) as cursor:
            for row in cursor:
                row[0] = polygon2.difference(polygon1)
                cursor.updateRow(row)
                edited_polygon_count += 1
    else:
            "edited_polygon", ["SHAPE@"], f"OBJECTID = {oid1}"
        ) as cursor:
            for row in cursor:
                row[0] = polygon1.difference(polygon2)
  1. Display the output message.
if overlap_count > 0:
    msg = (
        f"Success: {overlap_count} cross-edged area successfully removed. "
        f"{edited_polygon_count} polygon geometry updated."
    arcpy.AddMessage(msg)
    print(msg)
else:
    msg = "No cross-edged polygons were detected. No polygon geometry was modified."
    arcpy.AddWarning(msg)
    print(msg)
The following code shows the full sample script.
import arcpy
# define input polygon layer (must exist in the map)
# Create a copy of the feature layer
# Initialize counters
overlap_count = 0           # number of cross-edged AREAS
edited_polygon_count = 0   # number of polygon geometries edited
# Get a dictionary of OIDs and geometries
polygon_dict = {
    row[0]: row[1]
# pairwise compare all polygons
    # skip if polygons are completely disjoint
        continue
    # skip if containment exists (polygon fully within another polygon)
        continue
    # get intersecting geometry (cross-edge overlap candidate)
        continue
    # a cross-edged area is detected
    overlap_count += 1
    # remove overlap area from the polygon
        ) as cursor:
            for row in cursor:
    else:
        ) as cursor:
            for row in cursor:
# Executed when one or more cross-edged areas are detected and removed
    msg = (
    print(msg)
else:
    print(msg)
  1. Press Enter twice to execute the Python code.
The output message below summarize the number of cross-edged areas removed and the number of polygons updated.
The output message
The map below displays the middle polygon with two cross-edged areas from other polygons removed.
The polygon without the cross-edged area
Article ID: 000041290
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
