HOW TO
Remove a table from a project through Avenue
Summary
Sample code for removing a document from a project using Avenue
Procedure
  1. Open a New Script window.
  2. Copy and paste this code.
    Code:
    '-- Assumes you have a document called View1 in the project
    theView = av.GetProject.FindDoc("View1")
    av.GetProject.RemoveDoc(theView)
    '-- Assumes you have a document called Table1.dbf in the project
    theTable = av.GetProject.FindDoc("Table1.dbf")
    av.GetProject.RemoveDoc(theTable)
    '-- Assumes you have a document called Layout1 in the project
    theLayout = av.GetProject.FindDoc("Layout1")
    av.GetProject.RemoveDoc(theLayout)
  3. Compile the script and run it.
Article ID:000002499
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
