HOW TO
Relocate the temp directory of Portal for ArcGIS
Last Published: July 29, 2022
Summary
Files in the temp directory are stored in C:\arcgis\arcgisportal\temp by default. In instances when the drive runs out of storage space, the webgisdr process fails. The workflow to relocate the Portal for ArcGIS temp directory to a drive with more storage space is provided in this article.
Procedure
  1. Navigate to the Portal Administrator Directory. The URL is as follows:
https://<machine_name>.<domain>.com/<webadaptorhost>/portaladmin
  1. Log in to the Portal Administrator Directory using administrator credentials.
  2. Add the /system/directories/temp components to the end of the Portal Administrator Directory URL and navigate to it. The edited URL is as follows:
https://<machine_name>.<domain>.com/<webadaptorhost>/portaladmin/system/directories/temp
  1. Under Supported Operations, click Edit Directory.
The Portal Administrator Directory page to select Edit Directory option.
  1. Change the existing path of the directory to a new path. Refer to ArcGIS REST APIs: Edit Directory for more instructions.
The new path must be a local directory for each Portal for ArcGIS machine (not a network share) and the update does not create or populate the new folder.
  1. Click Edit Directory to save the new path for the directory.
Article ID: 000028009
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
