HOW TO
Re-create a new publishing tool from an existing JSON script in ArcGIS Server
First Published: January 1, 2021
Last Published: March 10, 2026
Summary
Server publishing tools can be corrupted due to unknown reasons, and therefore must be re-created for the server to continue working as intended. Using an administrator account, the publishing tools service can be re-created through the ArcGIS Server Administrator Directory by copying the existing JSON script of the current publishing tool. This article provides the workflow.
Procedure
  1. Log in to the ArcGIS Server Administrator Directory with an administrator account and click services.
  2. In the ArcGIS Server Administrative Directory window, under Folders, click System.
Select System in ArcGIS Server Administrator Directory
  1. On the Folder - System page, under Services, click PublishingTools (GPServer).
  2. On the Service - PublishingTools (GPServer) page, under Supported Operations, click edit.
Navigate to edit
  1. On the Edit GPServer page, in the Service (in JSON format) text box, copy the JSON script and paste it in a text editor, for example, Notepad.
  2. Search for the isDefault parameter. Change the value to false. Click Save.
  3. Return to the Service - PublishingTools (GPServer) page, under Supported Operations, click delete.
  4. Return to the Folder - System page, under Supported Operations, click createService.
  5. On the Create Service page, paste the JSON script copied in Step 5 into the Service (in JSON format) text box. Click Create.
Recreate the service
  1. Restart the ArcGIS Server services. Refer to ArcGIS Server: Start and stop services for instructions.
Article ID: 000024943
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
