HOW TO
Re-establish the relationship class for geodatabase attachments in ArcGIS Pro
First Published: December 3, 2025
Last Published: December 3, 2025
Summary
When attachments are enabled on a geodatabase feature class, ArcGIS Pro automatically creates a relationship class linking the feature class to the associated attachment table. If this relationship class is deleted, it cannot be restored by manually recreating a new relationship class or re-enabling attachments. Once removed, the connection between the feature class and the attachment table is broken, and new attachments can no longer be added.
This article describes the workflow to re-establish the relationship class between a feature class and the attachment table to restore full attachment functionality.
Cause
This issue occurs when the map image layer containing the feature layer is not shared with the same group. Feature layers published from a map service with feature access enabled depend on the map image layer for access and display. If the map image layer is not shared with the group, members cannot access the corresponding feature layers in ArcGIS Field Maps, even if the feature layers are shared separately. Refer to Portal for ArcGIS: Share items for more information.
Procedure
  1. Open the ArcGIS Pro project containing the feature class.
  2. In the Catalog pane, copy the feature class to the same geodatabase. The copied feature class is renamed with a '_1' suffix.
  3. Use the Enable Attachments tool to enable attachments for the new feature class. Refer to ArcGIS Pro: Find a geoprocessing tool for instructions to find and use the geoprocessing tool.
  4. In the Catalog pane, right-click the ATTACH table of the new feature class and click Load Data.
The ATTACH table of the new feature class in the Catalog pane
  1. In the Append pane, for Input Datasets, click Browse.
  2. In the Input Datasets dialog box, navigate to and select the original feature class ATTACH table. Click OK.
The selected original feature class ATTACH table in the Input Datasets dialog box
  1. In the Append pane, click Run.
The relationship class is re-established, linking the new feature class to its attachment table and restoring full attachment functionality.
The re-established relationship class for the feature layer and its attachment table
Article ID: 000038921
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
