HOW TO
Publish CAD data as a hosted feature service in ArcGIS Online
Last Published: August 9, 2023
Summary
Computer-aided design (CAD) data such as AutoCAD's DWG file and Bentley MicroStation's DGN file can be integrated with ArcGIS Pro maps as feature datasets. However, these file formats are not supported in ArcGIS Online, so the data must be converted to a file geodatabase feature in ArcGIS Pro before they are published as a hosted feature service to ArcGIS Online.
Procedure
  1. Convert the CAD dataset to a file geodatabase in ArcGIS Pro.
    1. On the ArcGIS Pro ribbon, click the Analysis tab > Tools.
    2. In the Geoprocessing pane, search for the CAD To Geodatabase tool, and click it.
    3. For Input CAD Datasets, select the CAD dataset to be converted.
    4. For Output Geodatabase, specify the file geodatabase for the output dataset.
    5. For Dataset, specify a name for the dataset created.
    6. For Reference scale, specify a reference scale.
    7. For Spatial Reference, select Current Map [Map] from the drop-down menu.
Image of the CAD to Geodatabase pane
  1. Click Run.
  1. Publish the file geodatabase to ArcGIS Online. Refer to ArcGIS Pro: Share a web feature layer using the default configuration for instructions.
Article ID: 000024862
Software:
  • ArcGIS Online
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
