HOW TO
The best practice workflow when publishing cached raster tiles into ArcGIS Enterprise is to create a map in ArcGIS Pro, then publish the map and choose the option to create the cache manually. This creates an empty service, and the Manage Map Server Cache geoprocessing tool can then be used to create the cache. This option uses the ArcGIS Online tiling scheme, which uses WGS84 and has pre-defined levels of detail.
If you need a non-WGS84 Web Mercator projection and a custom level of details, use the Generate Map Server Tiling Scheme geoprocessing tool first to create a custom tiling schema. Once the scheme file is generated, use it in the next steps to publish your data.
Note: It is best to try the process on a small area first as a prototype (for example. only a small local government area or few suburbs ). Once we are happy with the workflow and verified the process is working, we can then scale it up to the whole area of interest.
Use the Manage Map Server Cache Tiles geoprocessing tool to create the tiles. Select the service you just published as the input service, this reads all the scales defined in the previous steps when selecting the tile scheme. You can select them all, leave the update mode, and select Recreate All Tiles. This takes a while until all the tiles are created. Use an area of interest, so the tiles are not generated for unneeded areas. Check the box to wait for the job to finish. This makes it asynchronous and you don’t have to wait for the caching to finish. This generates the cache on the server site and frees the client application (for example, ArcGIS Pro).
When publishing raster data (for example, mosaic datasets) initiate the publishing from the Catalog pane by right-clicking the mosaic dataset or the raster file and then clicking Share as web layer. This ensures the service is published as an Imagery Service. Set the rest of the parameters similar to publishing a Map Image Layer. This creates an Imagery Layer on your Portal. Once the service is published, run the Manage Map Server Cache Tiles geoprocessing tool and this generates the tile cache under the ArcGIS Server cache directory (the default cache directory is C:\arcgis\arcgisserver\directories\arcgiscache) as shown in the image below. The _alllayers folder contains the actual bundle files for each level of details.
Article ID: 000031272
Get help from ArcGIS experts
Start chatting now
