HOW TO
Project raster datasets in ArcGIS 8.x with a sample executable
Summary
Projecting raster datasets in ArcGIS can be achieved through two methods: IRasterGeometryProc::ProjectFast or IRasterProps::SpatialReference. Both methods are based on a single polynomial transformation with 16 X 16 control points, regardless how big the images are.
There can be some distortion when the image covers a large area, or is close to the poles. Best results are obtained when the image is less than one degree in extent, and is between -70 and 70 degrees latitude.
If desired, highly accurate results can be obtained by using Workstation ArcInfo's PROJECT command with the grid option to perform a cell-by-cell projection.
Procedure
  • To get the sample tool "Projecting Raster Datasets", click the link ArcGIS 8.x in the Related Information below, and navigate to Samples > Raster > Projecting Raster Datasets.
Article ID:000005403
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
