HOW TO
Project images using ArcObjects sample code
Summary
Images can be projected from one coordinate system to another and saved to one of the three output formats using the following sample script. Note: this script is provided as is and is not supported by ESRI Technical Support.
Procedure
  1. Start ArcMap.
  2. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  3. In the Project Explorer window, expand Project.mxt and select ArcMap Objects > ThisDocument. Right-click and click View Code.
    [O-Image] Visual Basic Project  Explorer
    Code in the ThisDocument code module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
  4. Copy the following code into the code module:
    Public Sub ProjectThisImage()
    ' Instantiate a WorkspaceFactory object.
    Dim pWrkFac As IWorkspaceFactory
    Set pWrkFac = New RasterWorkspaceFactory
    ' Initialize and set the path to the Raster Workspace.
    Dim strPath As String
    strPath = "c:\temp"
    ' Open the raster workspace.
    Dim pRasterWorkspace As IRasterWorkspace
    Set pRasterWorkspace = pWrkFac.OpenFromFile(strPath, 0)
    ' Initialize and set the name of the input image.
    Dim strInName As String
    strInName = "myimage.tif"
    ' Open the raster dataset.
    Dim pRasterDataset As IRasterDataset
    Set pRasterDataset = pRasterWorkspace.OpenRasterDataset(strInName)
    ' Change from RasterDataset to RasterLayer.
    Dim pRasterLayer As IRasterLayer
    Set pRasterLayer = New RasterLayer
    pRasterLayer.CreateFromDataset pRasterDataset
    ' Instantiate the raster from the raster layer.
    Dim pRaster As IRaster
    Set pRaster = pRasterLayer.Raster
    Dim pRasterProps As IRasterProps
    Set pRasterProps = pRaster
    ' QI from IRaster to IRasterProps
    ' Get the current cell size.
    Dim pCell As IPoint
    Set pCell = New Point
    pCell.X = pRasterProps.MeanCellSize.X
    pCell.Y = pRasterProps.MeanCellSize.Y
    ' Create a new raster geometry process.
    Dim pRasGeoProc As IRasterGeometryProc
    Set pRasGeoProc = New RasterGeometryProc
    ' Set the spatial reference to UTM, Zone 18N, NAD83.
    Dim pSpatRefFac As ISpatialReferenceFactory2
    Set pSpatRefFac = New SpatialReferenceEnvironment
    Dim pSpatRef As ISpatialReference
    Set pSpatRef = pSpatRefFac.CreateProjectedCoordinateSystem(esriSRProjCS_NAD1983UTM_18N)
    ' Project the image to the new spatial reference.
    pRasGeoProc.ProjectFast pSpatRef, RSP_NearestNeighbor, , pRaster
    'pRasGeoProc.ProjectFast pSpatRef, RSP_NearestNeighbor, pCell, pRaster
    ' Instantiate a new Raster Band Collection.
    Dim pRasterBandCollection As IRasterBandCollection
    Set pRasterBandCollection = pRaster
    ' Set the new image name.
    Dim strOutName As String
    strOutName = "mynewimage.tif"
    ' Set the output raster type.
    Dim strOutType As String
    strOutType = "TIFF"
    'NOTE: This can be one of three types: "TIFF", "GRID", or "IMAGINE Image";
    'the extension on the file should be changed accordingly.
    ' Save the projected raster to the new name.
    pRasterBandCollection.SaveAs strOutName, pRasterWorkspace, strOutType
    'Clean the objects out of memory.
    Set pWrkFac = Nothing
    Set pRasterWorkspace = Nothing
    Set pRasterDataset = Nothing
    Set pRaster = Nothing
    Set pRasterProps = Nothing
    Set pCell = Nothing
    Set pRasGeoProc = Nothing
    Set pSpatRefFac = Nothing
    Set pSpatRef = Nothing
    Set pRasterBandCollection = Nothing
    End Sub
  5. Close the Visual Basic Editor.
  6. Run the code.
    A. Click Tools > Macros > Macros to display the Macros dialog box.
    B. Select a macro and click Run.
Article ID:000004509
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
