HOW TO
Programmatically update a password change in an ArcGIS Server registered data store
Last Published: July 27, 2022
Summary
In some cases, it is necessary to perform a scheduled password change on a data source registered in ArcGIS Data Store such as a database to maintain secured access. This is possible by manually importing the .sde connection file from ArcGIS Server. However, with multiple .sde files to be imported, the process can be tedious for an organization. The arcgis.gis module in ArcGIS API for Python can automate the process.
This article provides steps to automate a password change in a registered data store.
Procedure
  1. Import the necessary modules.
import arcpy
from arcgis.gis import GIS
  1. Connect to the portal using an administrator account.
gis = GIS("https://machine_name.domain:7443/arcgis/home","username", "password", verify_cert=False)
print("connected")
  1. List all available servers in the portal.
dstores = server1.datastores.list()
dstores
  1. Create a .sde file to connect to the database. Refer to ArcGIS Pro: Create Database Connection (Data Management) for more information.
arcpy.CreateDatabaseConnection_management("C:\\MyProject", "test.sde", "SQL_SERVER", "SQL Server", "OPERATING_SYSTEM_AUTH")
  1. Create a connection string for the database to be updated using the generate_connection_string() method. The code generates a connection string to be used when creating a new data item.
server1.datastores.generate_connection_string(r"C:\\MyProject\test.sde")
Sample result of connection string for ArcGIS Data Store
  1. Find the index of datastore items from the listed datastores in Step 3.
ds = dstores[N]
ds
  1. Create a data item with the updated password.
pro2 = {
  "path": "/enterpriseDatabases/testDsfunc",  //a unique path on the server
  "type": "egdb", //as this is a database
  "info": {
    "dataStoreConnectionType": "shared",
    "isManaged": "false",
    "connectionString": "<Connection string result from step 4>"
  1. Update the password in the data store.
ds.update(pro2)
The following shows the full code:
gis = GIS("https://machine_name.domain:7443/arcgis/home","username", "username", verify_cert=False)
print("connected")
gis_servers = gis.admin.servers.list()
gis_servers
server1 = gis_servers[0]
dstores
arcpy.CreateDatabaseConnection_management("C:\Users\user\Desktop\Test", "test.sde", "SQL_SERVER", "SQL Server", "OPERATING_SYSTEM_AUTH")
server1.datastores.generate_connection_string(r"C:\Users\user\Desktop\Test\test.sde")
ds = dstores[9]
ds
pro2 = {
  "info": {
    "connectionString": "ENCRYPTED_PASSWORD=sample_1;SERVER=User;INSTANCE=sde:sqlserver:User;DBCLIENT=sqlserver;DB_CONNECTION_PROPERTIES=User;DATABASE=dsfunc;USER=sde;VERSION=sde.DEFAULT;AUTHENTICATION_MODE=DBMS"
ds.update(pro2)
Article ID: 000022551
Software:
  • ArcGIS Data Store
  • ArcGIS API for Python 1 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
