HOW TO
Note: This article pertains to ArcGIS versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
This VBA example illustrates how you can programmatically select a NorthArrow and place it on the PageLayout in a specified location.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
Dim pStyleGallery As IStyleGallery Dim pEnum As IEnumStyleGalleryItem Dim pStyleGalleryItem As IStyleGalleryItem Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Set pStyleGallery = pMxDoc.StyleGallery Set pEnum = pStyleGallery.Items("North Arrows", "ESRI.Style", "Default") pEnum.Reset '***** Based on the index position of the North Arrow, the following lines of code select the arrow from the StyleGallery. '***** To see the NorthArrow you want, click the Insert Menu and select NorthArrow '***** Change the number 5 (below) to the NorthArrow's position in the StyleSelector. Dim intX As Integer For intX = 1 To 5 ' Change '5' to the desired index number Set pStyleGalleryItem = pEnum.Next Next Dim pArrow As INorthArrow Set pArrow = pStyleGalleryItem.Item Call NorthArrowAdder(pArrow)
Code: Public Sub NorthArrowAdder(pArrow As INorthArrow) '***** This subroutine '***** -- creates the MapSurroundFrame '***** -- changes the NorthArrow color to red '***** -- displays the NorthArrow on the PageLayout Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pAv As IActiveView Dim pGC As IGraphicsContainer Set pGC = pMxDoc.ActiveView '***** A MapSurround refers to 'things' that enhance a map, for example, '***** ScaleBars, Legends, and NorthArrows. Dim pMapSurround As IMapSurround Set pMapSurround = pArrow ' QI '***** Color the NorthArrow red to illustrate that we have access to its properties. Dim pClr As IRgbColor Set pClr = New RgbColor pClr.Red = 255 pArrow.Color = pClr '***** In order to be displayed on a PageLayout, all MapSurrounds must reside in '***** a frame (MapsurroundFrame). Dim pMapSurroundFrame As IMapSurroundFrame '****************************************************************** '***** CreateSurroundFrame ties the MapFrame to the MapsurroundFrame to '***** handle repositioning when moving/re-sizing. Dim pMapFrame As IMapFrame Set pMapFrame = pGC.FindFrame(pMxDoc.Maps.Item(0)) Dim pUid As UID Set pUid = New UID pUid.Value = "esricore.MarkerNorthArrow" Set pMapSurroundFrame = pMapFrame.CreateSurroundFrame(pUid, pArrow) '******************************************************************** '******************************************************************** Set pAv = pMxDoc.ActiveView '***** QI and set an IElement interface. This interface give you acces to a '***** Geometry property. This geometry property (in this case) takes a rectangle/envelope '***** that represents a location on the PageLayout where the NorthArrow will be stored... Dim pElem As IElement Set pElem = pMapSurroundFrame '***** The 'TheGeometry' function returns an envelope. pElem.Geometry = TheGeometry '***** Finally add the element to the graphicsContainer pGC.AddElement pElem, 0 pMxDoc.ActiveView.Refresh End Sub Public Function TheGeometry() As IGeometry '***** This function creates a geometry that is used by the PageLayout as the '***** position to display the North Arrow. Dim pEnv As IEnvelope Set pEnv = New Envelope Dim pt1 As IPoint Set pt1 = New Point pt1.X = 1.5 pt1.Y = 1.5 Dim pt2 As IPoint Set pt2 = New Point pt2.X = 1.5 pt2.Y = 1.5 pEnv.LowerLeft = pt1 pEnv.UpperRight = pt2 Set TheGeometry = pEnv End Function
Article ID:000005677
Get help from ArcGIS experts
Download the Esri Support App
