HOW TO
Programmatically change layout templates in ArcMap using ArcObjects
Summary
Instructions provided describe steps to programmatically change layout templates in ArcMap using ArcObjects.
Procedure
  1. Start ArcMap.
  2. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  3. In the Project Explorer window, expand Project.mxt and select ArcMap Objects > ThisDocument then right-click and select View Code.
    [O-Image] Visual Basic Project  Explorer
    Code in the Project's ThisDocument code module will only run in the current map document. If you want to store the code in all your map documents open the Normal.mxt ThisDocument code module instead.
  4. Copy the following code into the code module. Change the path to match your MXT.
    Code:
    Sub SwitchLayout()
    Dim pGxFile As IGxFile
    Set pGxFile = New GxMap
    pGxFile.Path = "C:\arcgis\Bin\Templates\USA\centralusa.mxt"
    Dim pGxPageLayout As IGxMapPageLayout
    Set pGxPageLayout = pGxFile
    Dim pPageLayout As IPageLayout
    Set pPageLayout = pGxPageLayout.PageLayout
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    pPageLayout.ReplaceMaps pMxDoc.Maps
    Set pMxDoc.PageLayout = pPageLayout
    End Sub
  5. Close the Visual Basic Editor.
  6. Run the code.
    A. Click Tools > Macros > Macros to display the Macros dialog box.
    B. Select a macro and click Run.
Article ID:000007581
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
