HOW TO
Preserve Global IDs when appending features from a file geodatabase to a hosted feature layer in ArcGIS Online
Last Published: September 30, 2024
Summary
Sometimes, the Global ID field is not preserved when appending features from a file geodatabase to a hosted feature layer in ArcGIS Online. Preserving Global IDs is crucial, as they uniquely identify each feature and are often used to track relationships, sync data, and manage editing history, particularly in offline workflows and feature services.
This article provides a workflow for appending a file geodatabase to a hosted feature layer in ArcGIS Online using a Python script run in the Python window within ArcGIS Pro.
Procedure
  1. Open the project in ArcGIS Pro.
  2. Open the Python window. Refer to ArcGIS Pro: Python window for more information.
To preserve GlobalIDs and avoid the automatic creation of new GlobalIDs, ensure the GlobalID field is already present in the hosted feature layer.
  1. Run the following script:
    1. Define paths to the input file geodatabase and the target hosted feature layer.
import arcpy
file_gdb_path = r"<file_geodatabase_path>"
hosted_feature_layer = r"<hosted_feature_layer_URL>"
    1. Create a FieldMappings object. This object defines how the fields from the source (file geodatabase) are mapped to the target (hosted feature layer).
field_mappings = arcpy.FieldMappings()
    1. Create a FieldMap object for the Global ID field and set the output field properties for the GlobalID field.
global_id_field_map = arcpy.FieldMap()
global_id_field_map.addInputField(file_gdb_path, "GlobalID")
global_id_field_map.outputField.name = "GlobalID"
    1. Add the field map for Global ID to the FieldMappings object.
field_mappings.addFieldMap(global_id_field_map)
    1. Add field maps for other fields if needed. Replace <field_name> with the name of the field to be mapped.
field1_field_map = arcpy.FieldMap()
field1_field_map.addInputField(file_gdb_path, "<field_name>")
field1_field_map.outputField.name = "<field_name>"
field_mappings.addFieldMap(field1_field_map)
    1. Append the features to the hosted feature layer.
arcpy.Append_management(file_gdb_path, hosted_feature_layer, schema_type="NO_TEST", field_mapping=field_mappings)
The code block below demonstrates the full working script.
import arcpy
file_gdb_path = r"C:\Users\dpalzaniappan\Documents\ArcGIS\Projects\MyProject91\MyProject91.gdb\Testi"
hosted_feature_layer = r"https://services9.arcgis.com/LMjydzYxR6YFiqk8/arcgis/rest/services/Testio123/FeatureServer/0"
field1_field_map.addInputField(file_gdb_path, "Name")
field1_field_map.outputField.name = "Name"
The image below displays the Python script used in the Python window in ArcGIS Pro to append the file geodatabase to the hosted feature layer.
The Python script in the Python window
Article ID: 000032358
Software:
  • ArcGIS Online
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
