HOW TO
To use a hosted tile layer in ArcGIS Online within an offline map in ArcGIS Enterprise, the hosted tile layer must be added to Portal for ArcGIS as a tile service item with ArcGIS Online organizational credentials embedded.
By default, accessing a public ArcGIS Online hosted tile layer does not prompt the user for credentials.
However, when a public ArcGIS Online hosted tile layer is added to Portal for ArcGIS without credentials embedded, the service becomes unusable. This is because the offline map area generation process in Portal for ArcGIS runs the exportTiles operation on the tile service, and this process requires embedded credentials on all services it operates on to run successfully.
This article describes how to prepare an ArcGIS Online hosted tile layer for use as a basemap in an ArcGIS Enterprise offline map, by embedding the ArcGIS Online credentials into the service once it is added to Portal for ArcGIS.
Article ID: 000026620
Get help from ArcGIS experts
Start chatting now
