HOW TO
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instead of having default values and colors appear in the Symbol Selector dialog, you may want to populate the dialog with custom symbols, colors, and sizes.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
Dim pSymbolSelector As ISymbolSelector
Dim pMarkerIn As IMarkerSymbol
Dim pMarkerOut As IMarkerSymbol
Dim pSymbol As ISymbol
Dim pColorIn As IRgbColor
Dim pRGBColorOut As IRgbColor
Set pMarkerIn = New CharacterMarkerSymbol
Set pSymbolSelector = New SymbolSelector
Set pColorIn = New RgbColor
pColorIn.Red = 25
pColorIn.Green = 25
pColorIn.Blue = 150
pMarkerIn.Color = pColorIn
pMarkerIn.Angle = 45
pMarkerIn.Size = 15
' X and Y Offset values are not persisted.
' This is a known issue.
' pMarkerIn.XOffset = -5
' pMarkerIn.YOffset = 2
pSymbolSelector.AddSymbol pMarkerIn
If pSymbolSelector.SelectSymbol(0) Then
' The SymbolSelect Dialog popped up
Set pSymbol = pSymbolSelector.GetSymbolAt(0)
' Capture the values set by the user
Set pMarkerOut = pSymbol
Set pRGBColorOut = pMarkerOut.Color
Else
MsgBox "User cancelled"
End If
Note: Values for the XOffset and YOffset propeties of the symbol object do not persist. This is a known issue.
Article ID: 000005715
Get help from ArcGIS experts
Start chatting now
