HOW TO
Place a layer from a geodatabase onto an ArcGIS Pro map using a Python script
First Published: October 20, 2022
Last Published: February 20, 2025
Summary
Features are added to the map for visualization when performing any process in ArcGIS Pro. When added to an opened map, these features are automatically converted into a layer file. For a feature in a geodatabase to be added to a map using a Python script, the feature must be converted into a layer file. Therefore to place a feature onto a map without opening the ArcGIS Pro software, the Make Feature Layer and Save To Layer File tools are used in the script to convert the desired feature from a geodatabase into a layer file.
The following workflow describes how to add features to an existing map using a Python script.
Procedure
  1. Import the necessary modules.
import arcpy
  1. Specify the workspace and the ArcGIS Project file location.
arcpy.env.workspace = r"<folder_location>\<geodatabase.gdb>"
project_path = r"<folder_location>\<project_name.aprx>"
aprx = arcpy.mp.ArcGISProject(project_path)
  1. Specify the parameters to be used in the Make Feature Layer and Save To Layer File tools.
layer = r"<folder_location>\<geodatabase.gdb>\<file_name>"
layers_out = "<output_file_name>"
output_location = r"<folder_location>\{}.lyrx".format(layers_out) #Same as project path
  1. Call the Make Feature Layer and Save To Layer File tools.
arcpy.management.MakeFeatureLayer(in_layer, "<output_file_name>")
arcpy.management.SaveToLayerFile("<output_file_name>" , layers_out)
  1. Insert the layer into the map in reference to an existing layer.
insertLyr = arcpy.mp.LayerFile(output_location)
m = aprx.listMaps("*")[0]
refLyr = m.listLayers("file_name")[0]
m.insertLayer(refLyr, insertLyr, "BEFORE")
  1. Save the project file.
aprx.save()
  1. Clear the lock file of the project.
del aprx
The code block below demonstrates the full script.
import arcpy
arcpy.env.workspace = r"C:\USER\Desktop\Test\test.gdb"
project_path = r"C:\USER\Desktop\Test\Test_Project.aprx"
layer = r"C:\USER\Desktop\Test\test.gdb\Layer_Test" #The feature name in the geodatabase
layers_out = "Layer_Test" #The file name for the output layer
output_location = r"C:\USER\Desktop\Test\{}.lyrx".format(layers_out)
arcpy.management.MakeFeatureLayer(in_layer, "Layer_Test")
arcpy.management.SaveToLayerFile("Layer_Test" , layers_out)
refLyr = m.listLayers("Existing_Layer")[0]
m.insertLayer(refLyr, insertLyr, "BEFORE") #Insert the new layer onto the map before the specified existing layer
aprx.save()
del aprx #Close the project and delete the lock file
Article ID: 000028522
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
