HOW TO
Instructions provided illustrate how to duplicate the functionality of ArcMap's spatial selection 'share a line segment with' through ArcObjects code.
Code in the Project's ThisDocument code module will only run in the current map document. If you want to store the code in all map documents open the Normal.mxt ThisDocument code module.
Code:
Option Explicit
Public Sub SelectPolyAsSharesSegementWith()
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pMap As IMap
Set pMap = pMxDoc.FocusMap
' Union all of the search features into one geometry and strip off
' it's boundary for use in the search. Since we are only interested
' in shared segments, not areas, the boundary is all that is needed.
' Get search layer
Dim pPolygonLyr As IFeatureLayer
Set pPolygonLyr = pMap.Layer(1)
Dim pLFeatClass As IFeatureClass
Set pLFeatClass = pPolygonLyr.FeatureClass
' Loop through the polygons, simplify them and then
' add them to a Geometry Bag.
Dim pFeatureCursor As IFeatureCursor
Set pFeatureCursor = pLFeatClass.Search(Nothing, True)
Dim pFeature As IFeature
Set pFeature = pFeatureCursor.NextFeature
Dim pGeometryCollection As IGeometryCollection
Set pGeometryCollection = New GeometryBag
Dim pTopologicalOperator2 As ITopologicalOperator2
Do While Not pFeature Is Nothing
Set pTopologicalOperator2 = pFeature.ShapeCopy
pTopologicalOperator2.IsKnownSimple = False
pTopologicalOperator2.Simplify
pGeometryCollection.AddGeometry pTopologicalOperator2
Loop
' Union all the polygons
Dim pTopologicalOperator1 As ITopologicalOperator2
Set pTopologicalOperator1 = New Polygon
pTopologicalOperator1.ConstructUnion pGeometryCollection
' Construct the boundary of the unioned polygons
Dim pTopologicalOperator3 As ITopologicalOperator2
Set pTopologicalOperator3 = New Polyline
Set pTopologicalOperator3 = pTopologicalOperator1.Boundary
' Use the boundary to find the candidate features
' Get the target FeatureClass
Dim pFeatureLayer As IFeatureLayer
Set pFeatureLayer = pMap.Layer(0)
Dim pFeatureClass As IFeatureClass
Set pFeatureClass = pFeatureLayer.FeatureClass
' Set up a scratch workspace to use for the selection
Dim pScratchWorkspace As IWorkspace
Dim pScratchWorkspaceFactory As IScratchWorkspaceFactory
Set pScratchWorkspaceFactory = New ScratchWorkspaceFactory
Set pScratchWorkspace = pScratchWorkspaceFactory.DefaultScratchWorkspace
' Setup the spatial filter
Dim pSpatialFilter As ISpatialFilter
Set pSpatialFilter = New SpatialFilter
With pSpatialFilter
Set .Geometry = pTopologicalOperator3
.GeometryField = "SHAPE"
.SpatialRel = esriSpatialRelIntersects
End With
' Perform the search and create a selection set
Dim pTempSelection As ISelectionSet
Set pTempSelection = pFeatureClass.Select(pSpatialFilter, esriSelectionTypeIDSet, esriSelectionOptionNormal, pScratchWorkspace)
' Loop through the features and check to see if they share a segment
' with the search geometry. If they don't, remove them from the selection
' set.
' Create a feature cursor to allow us the examine the candidate features
Dim pTempFeatCur As IFeatureCursor
pTempSelection.Search Nothing, True, pTempFeatCur
Dim iOIDList(1) As Long
Dim iOIDListCount As Long
iOIDListCount = 1
Dim pGeometry As IPolyline
Dim pTempFeat As IFeature
' Fetch the first feature
Set pTempFeat = pTempFeatCur.NextFeature
Dim pTempPolyline As IPolyline
' Check for the one dimentional intersection of the geometries.
' If there is no intersection the returned geometry will be empty. If
' it is, remove it from the selection set.
Dim pTopologicalOperator4 As ITopologicalOperator2
Set pTopologicalOperator4 = New Polygon
Do
iOIDList(0) = pTempFeat.OID
Set pTopologicalOperator4 = pTempFeat.ShapeCopy
pTopologicalOperator4.IsKnownSimple = False
pTopologicalOperator4.Simplify
Set pTempPolyline = pTopologicalOperator4.Boundary
Set pGeometry = pTopologicalOperator3.Intersect(pTempPolyline, esriGeometry1Dimension)
If pGeometry.IsEmpty Then
pTempSelection.RemoveList iOIDListCount, iOIDList(0)
End If
Loop Until pTempFeat Is Nothing
' Set the feature selection
Dim pFeatureSelection As IFeatureSelection
Set pFeatureSelection = pFeatureLayer
Set pFeatureSelection.SelectionSet = pTempSelection
' Display the selected features.
Dim pdoc As IMxDocument
Set pdoc = ThisDocument
pdoc.ActiveView.Refresh
End Sub
Article ID:000006784
Get help from ArcGIS experts
Download the Esri Support App
