HOW TO
Perform schema restores of an Oracle enterprise geodatabase
First Published: March 31, 2018
Last Published: August 4, 2025
Summary
This article describes a series of steps to perform when importing an Oracle Data Pump file by schema using the Data Pump import utility - impdp. These steps are meant to be run one at a time.
Versions Supported:
  • EGDB: All
  • DBMS: Oracle
  • DBMS Version: 11g and above
Procedure
  1. Create a new Oracle database.
  2. Connect as SYS via SQL*Plus.
sqlplus sys/syspassword@server/sid as sysdba
  1. Grant public permissions for Oracle geodatabase.
GRANT EXECUTE ON dbms_pipe TO public;
GRANT EXECUTE ON dbms_lock TO public;
GRANT EXECUTE ON dbms_lob TO public;
GRANT EXECUTE ON dbms_utility TO public;
GRANT EXECUTE ON dbms_sql TO public;
GRANT EXECUTE ON utl_raw TO public;
  1. Obtain list of owners that own data in the old enterprise geodatabase.
select distinct owner from sde.layers
union
select distinct owner from sde.st_geometry_columns
union
select distinct owner from sde.table_registry
order by 1;
  1. Create all required tablespaces.
This is a default tablespace to auto-extend.
CREATE TABLESPACE SDETBS DATAFILE '/home/oracle/orcl/oradata/banner/sde.dbf'
SIZE 100M AUTOEXTEND ON NEXT 51200K MAXSIZE UNLIMITED EXTENT MANAGEMENT
LOCAL UNIFORM SIZE 320K LOGGING ONLINE SEGMENT SPACE MANAGEMENT MANUAL;
  1. Create all required users/schema.
create user sde identified by sdepassword default tablespace sdetbs;
  1. Grant all necessary permissions to the new user.
grant CREATE SESSION to sde;
grant CREATE TABLE to sde;
grant CREATE TRIGGER to sde;
grant CREATE SEQUENCE to sde;
grant CREATE PROCEDURE to sde;
grant EXECUTE ON DBMS_CRYPTO to sde;
grant CREATE INDEXTYPE to sde;
grant CREATE LIBRARY to sde;
grant CREATE OPERATOR to sde;
grant CREATE PUBLIC SYNONYM to sde;
grant CREATE TYPE to sde;
grant CREATE VIEW to sde;
grant DROP PUBLIC SYNONYM to sde;
grant ADMINISTER DATABASE TRIGGER to sde;
grant ALTER ANY INDEX to sde;
grant ALTER ANY TABLE to sde;
grant CREATE ANY INDEX to sde;
grant CREATE ANY TRIGGER to sde;
grant CREATE ANY VIEW to sde;
grant DROP ANY INDEX to sde;
grant DROP ANY VIEW to sde;
grant SELECT ANY TABLE to sde;
grant ALTER SESSION to sde;
grant ANALYZE ANY to sde;
grant SELECT ANY DICTIONARY to sde;
grant CREATE DATABASE LINK to sde;
grant CREATE MATERIALIZED VIEW to sde;
grant RESTRICTED SESSION to sde;
grant UNLIMITED TABLESPACE to sde;
grant ALTER SYSTEM to sde;
grant SELECT_CATALOG_ROLE to sde;
  1. Create a directory for the SYSTEM user to access.
create directory DPUMP1 as '/home/oracle/dpump';
  1. Grant R/W to SYSTEM user to read the files in the directory.
GRANT READ, WRITE ON DIRECTORY DPUMP1 to system;
exit
  1. Run the impdp utility from the CMD window for each user schema.
  • Example 1: SDE Schema
impdp system/sys directory=dpump1 logfile=sde_imp.log dumpfile=backup.DMP schemas=sde
  • Example 2: GIS Schema
impdp system/sys directory=dpump1 logfile=GIS_imp.log dumpfile=backup.DMP schemas=GIS
  1. Log into SQL*Plus and check for invalid objects.
sqlplus sys/sys@server/sid as sysdba
Select count(*) from dba_objects where owner='SDE' and status='INVALID';
  1. Compile any invalid schema objects.
exec dbms_utility.compile_schema(schema => 'SDE');
Article ID: 000018063
Software:
  • Third Party Product
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
