HOW TO
Perform a simultaneous search of multiple log files using a Python script
Summary
When attempting to diagnose and troubleshoot errors, log files may contain detailed information of the problems encountered. However, some applications can generate multiple log files which may amount to a dozen or hundred files. For example, ArcGIS Server or ArcSDE may generate several server debug logs or SDE intercept log files. Searching and reviewing each log to identify a specific keyword related to the issues can be time consuming.
A simultaneous search of multiple log files for specific keywords can be performed using a Python script.
Procedure
The following is a sample python script separated into several sections for the purpose of this article. Combine all sections and execute the script:
  1. Import the necessary libraries.
    import os
  2. Specify the necessary parameters for the folder location, search keywords, and case sensitivity of the keywords.
    folder = r"E:\temp\logs"
    search_term = r"Keywords"
    case_sensitive = False
    The case_sensitive parameter requires a boolean value, either True or False.
  3. Define a new list index and the necessary array parameters for the search_files function.
    def search_files(folder, search_term, case_sensitive=False, results_file=""):
    fileslist = [f for f in os.listdir(folder) if os.path.isfile(os.path.join(folder, f))]
        foundinlist = []
        linelist = []
        fileerrors = 0
        totallines = 0
        for file in fileslist:
            print("Searching " + file)
            try:
                with open(os.path.join(folder, file)) as text:
                    if case_sensitive:
                        if search_term in text.read():
                            linenum = 1
                            foundinlist.append(file)
                            lineresults = "-- " + file + ":\n"
                            text.seek(0)
                            for line in text:
                                if search_term in line:
                                    lineresults = lineresults + str(linenum) + ", "
                                    totallines += 1
                                linenum += 1
                            linelist.append(lineresults[:-2])
                    else:
                        if search_term.lower() in text.read().lower():
                            linenum = 1
                            text.seek(0)
                            for line in text:
                                if search_term.lower() in line.lower():
                                    totallines += 1
                                linenum += 1
            except Exception as e:
                print("Error reading file: " + str(e))
                fileerrors += 1
  4. The print function prompts the system to return a statement if the search is successful or not.
    print(("Done searching " + str(len(fileslist) - fileerrors) + " of " + str(len(fileslist))
               + " files for '" + search_term + "'"))
        if fileerrors > 0:
            print("--> Error opening " + str(fileerrors) + " file(s)")
  5. This len function creates the list of results with full details.
    # results
        if len(foundinlist) > 0:
            print("\n\nSearch term found in " + str(len(foundinlist)) + " file(s):")
            for i in foundinlist:
                print(i)
            print("\n\nSearch term found on " + str(totallines) + " line(s):")
            for i in linelist:
                print(i)
            if results_file != "":
                results = ((["Searched " + str(len(fileslist) - fileerrors) + " of " + str(len(fileslist))
                             + " files for '" + search_term + "'"])
                           + ["\n\nSearch term found in " + str(len(foundinlist)) + " file(s):\n"]
                           + [i + "\n" for i in foundinlist]
                           + ["\n\nSearch term found on " + str(totallines) + " line(s)\n"]
                           + [i + "\n" for i in linelist]
                try:
                    with open(results_file, "w") as re_file:
                        re_file.writelines(results)
                        print("\nResults file written to:\n" + results_file)
                    print("\nResults file could NOT be written! Check your results file path")
                    print(e)
            return True
        else:
            print("\nNo matches found")
                print("\nResults file NOT written (no matches)")
            return False
  6. The search_files function calls and executes all the functions and defined parameters listed above.
    search_files(folder, search_term, case_sensitive, results_file)
The following is the combined sample script:
# Edit search parameters then execute the script.
# The function will attempt to open and search all files in the folder.
# Folders and unreadable files will be skipped.
# Folder path where files to search are located
# Search term
search_term = r"search term"
# Case sensitivity, True or False
# Path to write the results to file if desired (e.g. 'E:\temp\results.txt'),
#  "" for no results file.
results_file = r""
import os
    foundinlist = []
    linelist = []
    fileerrors = 0
    totallines = 0
        try:
                if case_sensitive:
                        linenum = 1
                        text.seek(0)
                        for line in text:
                                totallines += 1
                            linenum += 1
                else:
                        linenum = 1
                        text.seek(0)
                        for line in text:
                                totallines += 1
                            linenum += 1
            fileerrors += 1
    if fileerrors > 0:
    # results
            print(i)
        for i in linelist:
            print(i)
            try:
                print(e)
        return True
    else:
        return False
# run function
Article ID:000018989
Software:
  • ArcGIS Pro
  • ArcGIS API for Python 1 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
