HOW TO
Perform a keyfile selection in ArcMap
Summary
In ArcInfo Workstation, the RESELECT and ASELECT commands have a KEYFILE option. This allows features or records to be selected based on a separate look up table having matching values in a specified item.
This article provides an example of the syntax to perform a keyfile selection in ArcMap.
Procedure
In the Select By Attributes dialog, use SQL syntax such as the following:
Code:
[STATE] IN (select DISTINCT [STATE_NAME] from keyfile)
The sub query is first executed and returns a unique list of STATE_NAME values from the KEYFILE table. Features or records are then selected if matching values are found in the STATE column.
    Article ID:000007492
    Software:
    • ArcMap 9 x
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
