HOW TO
Obtain the widget ID in ArcGIS Experience Builder
First Published: August 13, 2025
Last Published: February 16, 2026
Summary
In ArcGIS Experience Builder, obtaining a widget ID included in the URL parameter provides a unique identifier, enabling precise control over the widget's actions, configurations, and interactions. Correct identification of the widget ID ensures the parameters and actions are applied to the intended widget, especially in applications with multiple widgets. However, this ID cannot be identified directly from the Experience Builder user interface and must be obtained through alternative methods, such as through browser developer tools or by enabling URL parameters for the widget in Experience Builder, and this article outlines the workflows.
Procedure
Use the Developer Tools feature
Open the Inspect Element of the browser with the published experience depending on the operating system used.
For Windows:
    1. Press Ctrl + Shift + I.
    2. On the Elements tab, search using widgetid for the preferred widget.
For macOS:
    1. Press Cmd + Option + I.
The published experience shows the widget ID (indicated in red outline) within the Inspect Element of the Legend widget
Enable the URL parameter of the widget in Experience Builder
This workflow applies only to the Map and Search widgets.
  1. Open the web experience in Experience Builder.
  2. Click the General The General icon tab. Under Experience settings, click the arrow The arrow icon next to State & URL parameters.
  3. In the State & URL parameters panel, under Widgets, click Page.
  4. In the Body section, under the preferred Page, toggle the preferred widget on. In this example, the NY_Map widget toggle is enabled.
The Map widget is enabled in the State & URL parameters panel
  1. Click Save The Save icon > Publish.
  2. Click More The More icon and select View published item.
  3. In the published experience, interact with the preferred map by zooming in or panning and obtain the widget ID from the URL. In this example, the widget ID in the URL is widget_5.
The URL link containing the widget ID (indicated in red outline)
Article ID: 000037594
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
