HOW TO
Moving the location of polygon label points is sometimes necessary when adding additional polygons within existing polygons or splitting polygons. This allows the correct attribute information of the original polygon to be preserved. The polygon where the modified label point resides after the edit, will contain the attribute information associated with the original polygon's label point prior to the edit.
Code:
Command: LABELMRK
Theme name (?/<MYSHAPES>):
Display using? (Properties/Item/<Symbol>):
Marker symbol number (0-100) (?/<0>):
Code:
Command: MODFEAT
Select objects: all
11 found
Select objects:
Optional property table (?/<none>):
8 modified in C:\ArcCAD\MYSHAPES, 3 ignored.
Code:
Output theme (?/<MYSHAPES>):
Packing MYSHAPES...
Building polygons...
Processing...
Sorting input file...
Sorting label file...
Processing...
Assigning final IDs...
Writing arc file...
Generating polygon report...
Creating Polygon attribute table.
Dropping entity-feature links...
Article ID:000002009
Get help from ArcGIS experts
Download the Esri Support App
