HOW TO
Instructions provided describe how to modify the output raster buffer size in Advanced ArcMap Settings.
The ArcMap Advanced Settings utility is a companion settings utility for ArcMap designed to give users safe access to customization settings for ArcMap that cannot be changed within the software itself. While administrative privileges are required to make many changes in the ArcMap Advanced Settings utility, those privileges are not required for the procedure described below, which operates on the user's registry settings only.
The utility never writes anything to the registry unless the Apply button is pressed, and then, it only writes settings for those values that have changed.
Article ID:000010498
Get help from ArcGIS experts
Download the Esri Support App
