HOW TO
When a user exports survey results from the Data tab of the ArcGIS Survey123 website as a CSV file, Excel file or file geodatabase, the database name values are displayed in the table instead of the user-specified labels. This is by design.
The name values follow the syntax of the database name values in ArcGIS Online; white spaces and special characters are not permitted. By default, the text for name values is set to lowercase. It is sometimes necessary to modify the stored name values before publishing the survey form. This article provides the steps to modify the name values using the Modify Schema settings on the ArcGIS Survey123 website before publishing the survey form.
Note: The name values can only be modified in the schema preview of the survey's feature layer in ArcGIS Survey123 before publishing a survey for the first time. Once published, changes to existing questions are not allowed.
Note: If valid changes are made to an existing survey form, a red dot is displayed on the top-right of Publish.
Note: The Name column displays the stored database name values. A pencil icon is displayed when hovering over a name value if it can be modified for a choice-based survey question.
The image below shows the modified name values of the exported table in ArcGIS Online.
Article ID: 000024344
Get help from ArcGIS experts
Start chatting now
