HOW TO
Merge multiple Triangulated Irregular Network (TIN) surfaces
Summary
Sometimes it is necessary to combine two or more Triangulated Irregular Network (TIN) surfaces together into a single TIN. There is no single geoprocessing tool that does this. However this can be done with the following workflow, using the TIN Node and Create TIN geoprocessing tools in combination.
Procedure
  1. Convert each of the TINs to be merged to point features using the TIN Node tool.
    [O-Image]
  2. Use the point features created in Step 1 as input to create a new TIN using the Create TIN tool.
    [O-Image]
Article ID:000011785
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
