HOW TO
In ArcGIS Pro, the distance between points and the nearest edge of a polygon can be measured. It can also be used to find how far a feature is from a border or boundary.
This article provides two workflows to measure the distance of point features to the nearest edge of a polygon using the Polygon To Line and Near tools, and the Feature To Line and Near tools. In these examples, the distance of the 'Supermarkets' point features to the nearest edge of the 'District A' polygon is measured.
Convert the polygon to a line feature using the Polygon To Line and Near tools.
The output generated from the Polygon To Line tool is an outline of the polygon layer as a new feature layer. In this example, 'DistrictA_PolygonToLine' is generated.
Note: Refer to ArcGIS Pro: Parameters for more information on the Near tool parameters.
The distance of each point feature to the nearest polygon edge is displayed in the 'NEAR_DIST' field.
Convert the polygon to a line feature using the Feature To Line and Near tools.
The output generated from the Feature To Line tool is an outline of the polygon layer as a new feature layer. In this example, 'DistrictA_FeatureToLine' is generated.
Article ID: 000029098
Get help from ArcGIS experts
Start chatting now
