HOW TO
Manually Rebuild the state_lineages Table (SQL Server)
Summary
**This article is ArcSDE version 9.2 specific**
Warning:
The information presented in this doc is internal only and should not be distributed outside of ESRI.
The purpose of this doc is to provide instructions on how to manually reduce the size of the state_lineages table so that compress will complete successfully.The error returned by compress when the size of the state_lineages table is an issue is:Error: Out of server memory (-12).
Error: Unable to compress state tree.This happens because the state_lineages table is too large to load into memory. Usually the table has 20M+ records.Scripts are provided below for SQL Server.Make sure that a database backup exists before attempting to run either of the scripts below.
Procedure
For SQL Server:
Code:
-- Rebuild State Lineages -- update both states and lineages tables.
-- Run the following script as the SDE user.
-- It requires creating a backup of the original state_lineages table,
-- dropping indexes on the states table
-- and then validating the procedure was successful.
-- Step 1
set nocount on
-- Check for inconsistency in states table.
if (select count(*) from sde.sde_states where parent_state_id NOT IN (SELECT state_id from sde.sde_states)) > 0
begin
print 'Inconsistent states table, must be repaired prior to executing routine...'
return
end
-- Backup sde_state_lineages table
if (object_id('sde_state_lineages_bk') is not null)
begin
print 'Dropping Existing sde_state_lineages_bk backup table...'
Drop table sde_state_lineages_bk
end
go
SELECT * into sde_state_lineages_bk FROM sde_state_lineages;
TRUNCATE TABLE sde_state_lineages;
-- backup sde_states table
if (object_id('sde_states_bk') is not null)
begin
print 'Dropping Existing sde_states_bk backup table...'
Drop table sde_states_bk
end
go
SELECT * into sde_states_bk FROM sde_states;
-- We need to drop the existing unique key constraint on the states table to allow us to modify lineage names.
ALTER TABLE sde_states DROP CONSTRAINT states_uk;
Declare @parent_prop_count int;
Declare @parent_prop_1 int;
Declare state_list CURSOR
for
SELECT state_id, parent_state_id
FROM sde_states
WHERE state_id > 0
ORDER BY state_id;
Declare @missing_state int;
Declare @current_state int;
Declare @parent_id int;
Declare @prev_lineage int;
set @missing_state = 0;
set @current_state = 0;
BEGIN
INSERT INTO sde_state_lineages VALUES (0,0);
Open state_list
fetch state_list into @current_state, @parent_id
while (@@fetch_status=0)
begin
IF @parent_id = 0
Begin
UPDATE sde_states SET lineage_name = @current_state WHERE state_id = @current_state;
INSERT INTO sde_state_lineages VALUES (@current_state, 0);
INSERT INTO sde_state_lineages VALUES (@current_state, @current_state);
End
ELSE
begin
set @parent_prop_count =
SELECT count(state_id)
FROM sde_states
WHERE parent_state_id = @parent_id
set @parent_prop_1 =
SELECT top 1 state_id
FROM sde_states
ORDER BY state_id
set @prev_lineage = (SELECT lineage_name FROM sde_states WHERE state_id = @parent_id);
IF (@parent_prop_count = 1) OR (@parent_prop_1 = @current_state)
begin
UPDATE sde_states SET lineage_name = @prev_lineage WHERE state_id = @current_state;
INSERT INTO sde_state_lineages VALUES (@prev_lineage, @current_state);
End
ELSE
Begin
INSERT INTO state_lineages
SELECT @current_state, lineage_id
FROM state_lineages
WHERE lineage_name = @prev_lineage
AND
lineage_id <= @parent_id
ORDER BY lineage_id;
END;
END;
END;
END;
close state_list
Deallocate state_list
-- Replace the unique index on the states table, this is very important because it's the mechanism which is
-- used to determine if a state needs a new lineage when it is created.
ALTER TABLE sde_states add CONSTRAINT [states_uk] UNIQUE NONCLUSTERED
[parent_state_id] ASC,
[lineage_name] ASC
-- Step 2
-- Function to return the ansester count of a state
if (object_id('TW_GetAncestorCount') is not null)
begin
print 'Dropping Existing procedure TW_GetAnsesterCount...'
Drop function TW_GetAncestorCount
end
go
create function TW_GetAncestorCount(@StateID int)
returns int
As
Begin
Declare @StCount int;
with stateTab (State_id, parent_state_id, lvl, sortcol)
as
select State_id, parent_state_id, 0, cast(State_id as varbinary(max))
from sde.sde_states
where state_id = @StateId
Union All
select S1.State_id, S1.parent_state_id, S2.lvl+1, cast(sortcol + cast(S1.State_id as BINARY(4)) as varbinary(max))
from sde.sde_states as S1
Join stateTab as S2
on (S2.parent_State_id = S1.State_id)
where not((s1.parent_state_id = 0) AND (s1.state_id = 0))
select @StCount = (select count(*)+1 from stateTab)
return @StCount
End
go
-- Step 3
-- The following procedure is used to validate each state's heirarchy and its corresponding state_lineage
-- by comparing the length of each state's lineage. If they are not the same, then there was an error
-- when building the state_lineage index.
Declare @num_states int;
Declare @num_lineages int;
Declare @Stateid int;
Declare @LineageName int;
DECLARE state_list cursor
for
SELECT state_id, lineage_name
FROM sde_states
WHERE state_id > 0
ORDER BY state_id;
Open state_list
fetch state_list into @stateid, @LineageName
begin
set @num_states = sde.TW_GetAncestorCount(@stateid)
set @num_lineages = (
SELECT COUNT(*)
WHERE lineage_name = @LineageName
AND lineage_id <= @stateid
IF @num_lineages <> @num_states
print 'State ' + str(@stateid) + ' lineage is corrupt...'
END;
close state_list
print 'If No other messages were printed, validation is complete!'
Article ID:000009739
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
