HOW TO
Manage the Application Server from the command line for ArcIMS 3.0
Summary
You can start, stop, add, and delete MapServices, Spatial Servers, and Virtual Servers from the command line.
Procedure
  • To manage the ArcIMS Application Server from the command line, first open a command prompt. From the command prompt you will use the following syntax:
    Code:
    java com.esri.aims.admincore.cmd.Exec <url> <user> <pword> <options> <commands>
    Where:
    url = http://host_web_server - Example: http://corleone
    user = login user name
    pword = login password
    options = cmd {used to specify an information tag follows}
    file {a file containing predefined commands}
    commands = filename or command to process:
    SERVICE - Gets all services
    VSERVER - Gets all Virtual Servers
    PSERVER - Gets all Physical (Spatial) Servers
    STATS - Gets stats for all Virtual Servers
  • The following examples show how to:
    Get Statistics:
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd STATS
    Get Services:
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd SERVICE
    Get Virtual Servers
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd VSERVER
    Get Physical (Spatial) Servers
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd PSERVER
  • The same command line syntax can be used to process XML batch files. The following illustrates how to do this with the sample testAddandStartService.xml and testStopandRemoveService.xml files:
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin file testAddandStartService.xml
    Here is the testAddandStartService.xml file:
    <?xml version="1.0" encoding="Cp1252"?>
    <ADMINCMD VERSION="0.1">
    <SERVICES>
    <SERVICE TYPE="ADD"
    NAME="WORLD1"
    AXL="c:\ArcIMS\Axl\world.axl"
    VSNAME="ImageServer1"
    IMGLOC="c:\arcims\output"
    IMGURL="http://corleone/output"
    CLEANUP="5"
    IMGTYPE="PNG"
    <SERVICE TYPE="START"
    NAME="WORLD1"
    <SERVICE TYPE="ADD"
    NAME="WORLD2"
    VSNAME="FeatureServer1"
    CLEANUP="5"
    IMGTYPE="PNG"
    NAME="WORLD2"
    <SERVICE TYPE="ADD"
    NAME="WORLD3"
    CLEANUP="5"
    IMGTYPE="PNG"
    NAME="WORLD3"
    <SERVICE TYPE="ADD"
    NAME="WORLD4"
    CLEANUP="5"
    IMGTYPE="PNG"
    NAME="WORLD4"
    </SERVICES>
    </ADMINCMD>
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin file testStopandRemoveService.xml
    Here is the testStopandRemoveService.xml file:
    <SERVICES>
    <SERVICE TYPE="STOP" NAME="WORLD1" />
    <SERVICE TYPE="REMOVE" NAME="WORLD1" />
    <SERVICE TYPE="STOP" NAME="WORLD2" />
    <SERVICE TYPE="REMOVE" NAME="WORLD2" />
    <SERVICE TYPE="STOP" NAME="WORLD3" />
    <SERVICE TYPE="REMOVE" NAME="WORLD3" />
    <SERVICE TYPE="STOP" NAME="WORLD4" />
    <SERVICE TYPE="REMOVE" NAME="WORLD4" />
    </SERVICES>
    </ADMINCMD>
    Click below to see the XML batch file syntax for managing:
    - Services (SERVICE)
    <SERVICES>
    <SERVICE TYPE={ ADD | CHANGE | REMOVE | START | STOP }
    NAME="WORLD1"
    AXL={Any valid axl file e.g. "c:\ArcIMS\Axl\world.axl"}
    VSNAME={Any valid Virtual Server name e.g. ImageServer1}
    CLEANUP={integer number}
    IMGTYPE={ PNG | GIF | JPG }
    </SERVICES>
    </ADMINCMD>
    - Physical (Spatial) Servers (PSERVER)
    <PSERVERS>
    <PSERVER TYPE={ ADD | REMOVE }
    ID={ unique id for this machine - usually added for you }
    MACHINE={ any machine that has monitor running on it }
    THREADS={ integer number of threads - used for virtual servers only }
    </PSERVERS>
    </ADMINCMD>
    - Spatial Servers (VSERVER)
    <VSERVERS>
    <VSERVER TYPE={ ADD | CHANGE | REMOVE }
    NAME={ Name of VSERVER }
    SERVICETYPE={ any valid server component (e.g. ImageServer) }
    <PSERVER ID={ ServerID } THREADS={ n } />
    </VSERVERS>
    </ADMINCMD>
Article ID:000002060
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
