HOW TO
ArcIMS Services, Spatial Servers, and Virtual Servers can be managed from the command line. In addition, information about an ArcIMS site can be retrieved using the command line. To manage ArcIMS from the command line, the ArcIMS servlet connector must be installed on the Web server. Reference to the hostname in this article is referencing the Web server hostname.
java com.esri.aims.admincore.cmd.Exec <url> <user> <pwd> <options> <commands>Where:
url = http://host_web_server - Example: http://arcims1 user = login user name for ArcIMS Administrator pwd = login password for ArcIMS Administrator options = cmd {used to specify an information tag follows} file {a file containing predefined commands} commands = filename or command to process: SERVICE - Gets all services VSERVER - Gets all Virtual Servers PSERVER - Gets all Physical (Spatial) Servers STATS - Gets stats for all Virtual Servers
Note: Information about an ArcIMS site can be retrieved using the command line. Note that the following jar files (installed with ArcIMS) must be in the Java runtime's classpath for the command line to function properly: jaxp.jar, parser.jar, esri_mo10.jar, esri_mo10res.jar, arcims_admincore.jar, arcims_admin.jar, jcert.jar, jnet.jar, jsse.jar, arcims_resadmin.jar. These jar files can be found under $AIMSHOME/Manager/lib.The following examples show how to:
java com.esri.aims.admincore.cmd.Exec http://arcims1 admin admin cmd STATSGet Services:
java com.esri.aims.admincore.cmd.Exec http://arcims1 admin admin cmd SERVICEGet Virtual Servers:
java com.esri.aims.admincore.cmd.Exec http://arcims1 admin admin cmd VSERVERGet Physical Servers:
java com.esri.aims.admincore.cmd.Exec http://arcims1 admin admin cmd PSERVERList computers that Monitor Services are running on:
java com.esri.aims.admincore.cmd.Exec http://arcims1 admin admin cmd MONITORSave the current site configuration:
java com.esri.aims.admincore.cmd.Exec http://arcims1 admin admin cmd SAVEManaging Services and Servers
java com.esri.aims.admincore.cmd.Exec <b>http://arcims1</b> admin admin file <b><drive>:\Folder_Name\</b>testAddSpatialandVirtualServer.xmlFor ArcIMS 3.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/arcims_sdk.jar:$JARHOME/arcims_ressdk.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testAddSpatialandVirtualServer.xmlFor ArcIMS 4.0 and 4.0.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/esri_mo10.jar:$JARHOME/esri_mo10res.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testAddSpatialandVirtualServer.xmlThe ADMINCMD.xml file testAddSpatialandVirtualServer.xml (includes threads from two physical servers):
<?xml version="1.0"?> <ADMINCMD version="1.0"> <PSERVERS> <PSERVER type="add" machine="<b>mymachine.domain.com</b>"/> </PSERVERS> <VSERVERS> <VSERVER type="add" name="MyIS" access="Public" description="My test VS" servicetype="ImageServer"> <PSERVER id="<b>mymachine.domain.com</b>_2" threads="3"/> <PSERVER id="<b>mymachine.domain.com</b>_1" threads="1"/> </VSERVER> </VSERVERS> </ADMINCMD>
Note: When adding a PSERVER (or spatial server) to your machine using the line <PSERVER type="add" machine="<b>mymachine.domain.com</b>"/> it will automatically be appened with a number. Spatial Servers are listed in numerical order, therefore if you have 3 Spatial Servers currently running the newly added Spatial Server will be mymachine.domain.com_4. You will have to update the batch file so that the line <PSERVER id="<b>mymachine.domain.com</b>_2" threads="3"/> reflects this.Add and start map services:
java com.esri.aims.admincore.cmd.Exec <b>http://arcims1</b> admin admin file <b><drive>:\Folder_Name\</b>testAddandStartMapService.xmlFor ArcIMS 3.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/arcims_sdk.jar:$JARHOME/arcims_ressdk.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testAddandStartMapService.xmlFor ArcIMS 4.0 and 4.0.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/esri_mo10.jar:$JARHOME/esri_mo10res.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testAddandStartMapService.xmlThe ADMINCMD.xml testAddandStartMapService.xml (This example will add an ImageService that uses the original ImageServer, an ImageService that uses the newly created ImageServer and a FeatureService that uses the original FeatureServer. For adding an ArcMapImageService please see the ArcXML Programmers reference guide.):
<?xml version="1.0"?> <ADMINCMD version="1.0"> <SERVICES> <SERVICE type="add" name="world_image" axl="<b><drive></b>:\arcims\axl\world.axl" vsname="ImageServer1" imgloc="<b><drive></b>:\arcims\output" imgurl="http://<b>mymachine.domain.com</b>/output" imagememory="4" cleanup="20" imgtype="JPG" /> <SERVICE type="start" name="world_image" /> <SERVICE type="add" name="world_image2" axl="<b><drive></b>:\arcims\axl\world.axl" vsname="MyIS" imgloc="<b><drive></b>:\arcims\output" imgurl="http://<b>mymachine.domain.com</b>/output" imagememory="4" cleanup="20" imgtype="JPG" /> <SERVICE type="start" name="world_image2" /> <SERVICE type="add" name="world_feature" axl="<b><drive></b>:\arcims\axl\world.axl" vsname="FeatureServer1"/> <SERVICE type="start" name="world_feature" /> </SERVICES> </ADMINCMD>
java com.esri.aims.admincore.cmd.Exec <b>http://arcims1</b> admin admin file <b><drive>:\Folder_Name\</b>testStopandDeleteServices.xmlFor ArcIMS 3.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/arcims_sdk.jar:$JARHOME/arcims_ressdk.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testStopandDeleteServices.xmlFor ArcIMS 4.0 and 4.0.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/esri_mo10.jar:$JARHOME/esri_mo10res.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testStopandDeleteServices.xmlThe ADMINCMD.xml testStopandDeleteServices.xml (This sample will stop and delete the above added services):
<?xml version="1.0"?> <ADMINCMD version="1.0"> <SERVICES> <SERVICE type="stop" name="world_image" /> <SERVICE type="remove" name="world_image" /> <SERVICE type="stop" name="world_image2" /> <SERVICE type="remove" name="world_image2" /> <SERVICE type="stop" name="world_feature" /> <SERVICE type="remove" name="world_feature" /> </SERVICES> </ADMINCMD>
java com.esri.aims.admincore.cmd.Exec <b>http://arcims1</b> admin admin file <b><drive>:\Folder_Name\</b>testDeleteSpatialandVirtualServer.xmlFor ArcIMS 3.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/arcims_sdk.jar:$JARHOME/arcims_ressdk.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testDeleteSpatialandVirtualServer.xmlFor ArcIMS 4.0 and 4.0.1 on UNIX:
#!/bin/csh setenv JARHOME $AIMSHOME/Manager/lib setenv AIMSHOST <b>http://arcims1</b> java -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/esri_mo10.jar:$JARHOME/esri_mo10res.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admincore.cmd.Exec http://$AIMSHOST <b>user_id password</b> file $FILEHOME/testDeleteSpatialandVirtualServer.xmlThe ADMINCMD.xml testDeleteSpatialandVirtualServer.xml (This sample will delete the previously added Spatial and Virtual Servers):
<?xml version="1.0" encoding="UTF8"?> <ADMINCMD version="1.0"> <VSERVERS> <VSERVER type="remove" name="MyIS"/> </VSERVERS> <PSERVERS> <PSERVER type="remove" machine="<b>mymachine.domain.com</b>" id="<b>mymachine.domain.com</b>_2"/> </PSERVERS> </ADMINCMD>
Article ID:000003838
Get help from ArcGIS experts
Download the Esri Support App
