HOW TO
Make Oracle external authentication connections (OSA for Oracle) using a Net Service Name
Summary
Instructions provided describe the steps to make Oracle external authentication connections (OSA for Oracle) using a Net Service Name. See Knowledge Base article 42269 for more information.
Procedure
1. Download the (32-bit) Oracle Instant Client from the ESRI Customer Care Portal, and unzip it to a location on the local ArcGIS Desktop machine. Change the name of the folder if desired.
EXAMPLE:
C:\OracleInstantClient_32
2. Add the Oracle Instant Client path to the beginning of the existing PATH (operating system) Environment Variable.
EXAMPLE:
PATH=C:\OracleInstantClient_32;...
3. Create a file called 'TNSNAMES.ORA' inside the Oracle Instant Client directory, and add an entry in the file specifying a desired Net Service Name, the Host machine name (with the local domain), and the Service Name.
EXAMPLE:
Code:
ORCL =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = ORASRVR.<yourDOMAINNAME>)(PORT = 1521))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = ORCL)
4. Create a file called 'SQLNET.ORA' inside the Oracle Instant Client directory and add this entry to the file:
SQLNET.AUTHENTICATION_SERVICES = (NTS)
Setting SQLNET.AUTHENTICATION_SERVICES = (NONE) does not suffice.
5. Create an Environment Variable on the Windows operating system called 'TNS_ADMIN' that references the location of the Oracle Instant Client directory.
[O-Image]
6. Launch ArcCatalog and make a connection using the Net Service Name and selecting the Operating System Authentication option from the drop-down (the username and password is grayed out).
[O-Image]
Article ID:000012022
Software:
  • Legacy Products
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
