HOW TO
Make Oracle database authentication connections using a Net Service Name
Summary
Instructions provided describe the steps to make Oracle database authentication connections using the Oracle Instant Client and a Net Service Name. See Knowledge Base article 42269 for more information.
Procedure
  1. Download the (32-bit) Oracle Instant Client from the ESRI Customer Care Portal, and unzip it to a location on the local ArcGIS Desktop machine. Change the name of the folder if desired.
    EXAMPLE:
    C:\OracleInstantClient_32
  2. Add the Oracle Instant Client path to the beginning of the existing PATH (operating system) Environment Variable.
    EXAMPLE:
    PATH=C:\OracleInstantClient_32;...
  3. Create a file called 'TNSNAMES.ORA' inside the Oracle Instant Client directory, and add an entry in the file specifying a desired Net Service Name, the Host machine name (with the local domain), and the Service Name.
    EXAMPLE:
    Code:
    ORCL =
    (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST = ORASRVR.<yourDOMAINNAME>)(PORT = 1521))
    (CONNECT_DATA =
    (SERVER = DEDICATED)
    (SERVICE_NAME = ORCL)
  4. Create an Environment Variable on the Windows operating system called 'TNS_ADMIN' that references the location of the Oracle Instant Client directory.
    [O-Image]
  5. Launch ArcCatalog and make a connection using the Net Service Name and selecting the Database Authentication option from the drop-down, and specify a username and password.
    [O-Image]
Article ID:000012021
Software:
  • ArcMap
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
