HOW TO
Calcapl.ave does not take NULL shapes into account. The NULL shapes get their values from the previous record. The QueryShape request requires that a 'valid' shape object exists first, and in the case of the NULL shapes this is not true; thus, when a value is assigned to the record, it uses the value that already existed in the variable.
Code:
'-- Name: View.CalculateFeatureGeometry
'-- Title: Calculates feature geometry values
'-- Topics: GeoData
'-- Description: This is a modified version of calcapl.ave script.
'-- It calculates area and perimeter for polygon themes and
'-- length for line themes. If the view has been projected the
'-- calculations are in projected meters. Otherwise the calculations
'-- are in native map units. Modify the script to provide
'-- calculation in the current report units of the view.
'-- The script processes the list of active themes to calculate
'-- area and perimeter, or length, depending on the theme type.
'-- The script will add the fields: Area and Perimeter to polygon
'-- themes. Length to line themes if they do not exist. If the fields
'-- exist their values will be recalculated. Rerun the
'-- script if you change the projection of the view.
'-- Requires: A view with at least one active theme. You must have
'-- write access to the active theme(s).
'-- Get the view and its projection if any.
theView = av.GetActiveDoc
thePrj = theView.GetProjection
if (thePrj.IsNull) then
hasPrj = false
else
hasPrj = true
end
'-- Get the list of active themes. if there aren't any,
'-- let the user know and exit.
theActivethemeList = theView.GetActivethemes
if (theActivethemeList.Count = 0) then
MsgBox.Error("No active themes.","")
Exit
end
'-- Loop through the list of active themes. if you can't
'-- edit the theme inform the user.
For Each thetheme in theActivethemeList
theFTab = thetheme.GetFTab
if (theFTab.CanEdit.Not) then
MsgBox.Info("Cannot edit table for theme:"++thetheme.AsString,"")
Continue
end
'-- Make the FTAB editable and find out the type of feature it is.
theFTab.SetEditable(TRUE)
theType = theFTab.FindField("shape").GetType
if (theType = #FIELD_SHAPEPOLY) then
'-- If it's polygonal check for the existence of the fields
'-- Area and Perimeter. if they do not exist, create them.
if (theFTab.FindField("Area") = nil) then
theAreaField = Field.Make("Area",#FIELD_DOUBLE,16,3)
theFTab.AddFields({theAreaField})
else
ok = MsgBox.YesNo("Update Area?", "Calculate", true)
if (ok.Not) then
continue
end
theAreaField = theFTab.FindField("Area")
end
if (theFTab.FindField("Perimeter") = nil) then
thePerimeterField = Field.Make("Perimeter",#FIELD_DOUBLE,16,3)
theFTab.AddFields({thePerimeterField})
else
ok = MsgBox.YesNo("Update Perimeter?", "Calculate", true)
if (ok.Not) then
continue
end
thePerimeterField = theFTab.FindField("Perimeter")
end
'-- Loop through the FTAB and find the projected area
'-- and perimeter of each shape and set the field values
'-- appropriately.
For Each rec in theFTab
theShape = theFTab.ReturnValue(theFTab.FindField("shape"),rec)
if(theShape.isNull) then
theArea = 0.0
thePerimeter = 0.0
else
theFTab.QueryShape(rec,thePrj,theShape)
theArea = theShape.ReturnArea
thePerimeter = theShape.ReturnLength
end
theFTab.SetValue(theAreaField,rec,theArea)
theFTab.SetValue(thePerimeterField,rec,thePerimeter)
end
elseif (theType = #FIELD_SHAPELINE) then
'-- If the data source is linear, check for the existence
'-- of the field "Length". if it doesn't exist, create it.
if (theFTab.FindField("Length") = nil) then
theLengthField = Field.Make("Length",#FIELD_DOUBLE,16,3)
theFTab.AddFields({theLengthField})
else
ok = MsgBox.YesNo("Update Length?", "Calculate", true)
if (ok.Not) then
continue
end
theLengthField = theFTab.FindField("Length")
end
'-- Loop through the FTAB and find the projected length of
'-- each shape and set the field values appropriately.
theLength = 0
else
theLength = theShape.ReturnLength
end
theFTab.SetValue(theLengthField,rec,theLength)
end
end
theFTab.SetEditable(FALSE)
end
Article ID:000004322
Get help from ArcGIS experts
Download the Esri Support App
