HOW TO
Locate Geospatial video files when flying Freefly Astro drones
First Published: March 21, 2025
Last Published: August 6, 2025
Summary
This article explains where to find the video and log files when flying missions with Freefly Astro drones.
Procedure
The process to retrieve the captured videos from the Astro, Astro Prime and Astro Max is different than DJI drones. The video is not stored in the external storage connected to the aircraft, instead, they are stored in the camera's SD card.
  1. Make sure the Astro is powered off.
  2. Look for the camera's SD card reader and retrieve the SD Card.
  3. Connect the SD card to a computer.
  4. Open the file explorer on your computer and access the SD Card.
  5. Navigate to: private > M4ROOT > CLIP
  6. Retrieve the video(s).
There is no indication or correlation in the naming convention between the video files and the video logs coming from the flight app. Keep this in mind when capturing video data so you can match them using the FMV workflow.
To complete the full motion video workflow, see the article: How to: Use Geospatial Log Files from Video Flights
Article ID: 000035416
Software:
  • ArcGIS Drone2Map
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
