HOW TO
List URLs from text fields in ArcGIS Pro using ArcPy
First Published: August 30, 2024
Last Published: August 30, 2024
Summary
In ArcGIS Pro, efficiently downloading data from every linked item listed in a table, where each item's URL is stored in a specific field, is possible. The SearchCursor function can be used to return rows of attribute values from a feature class or table. By iterating through the rows, the URLs can be extracted and listed from text fields containing only URL links, such as those starting with 'https' or 'www'. This approach provides streamlined data processing and facilitates further operations involving the extracted URLs. This article describes the workflow to list the URLs from the text fields using ArcPy.
The URLs in a text field of a stand-alone table in ArcGIS Pro
Procedure
This workflow requires a full script to run in the ArcGIS Pro Python window. The indents must be retained as portrayed in the code block.
  1. Open the project containing the URLs in ArcGIS Pro.
  2. Open the Python window. Refer to ArcGIS Pro: Python window for more information.
  3. Run the script below.
    1. To set the path of the stand-alone table:
import arcpy
table = r"<pathName>"
  1. To fetch and store information about the field containing the URLs:
url_field = "URL"
  1. To create a list to store the URLs:
url_list = []
  1. To search the records, identify, and retrieve the URLs based on their prefixes using SearchCursor and startswith():
with arcpy.da.SearchCursor(table, [url_field]) as cursor:
    for row in cursor:
        url = row[0]
        if url is not None:
            if url.startswith('https') or url.startswith('www'):
                url_list.append(url)
            else:
                pass
  1. To print the results:
for url in url_list:
    print(url)
The code block below demonstrates the full working script.
import arcpy
table = r" C:\Training\StartAnalytics\Data\FarmAnalysis.gdb\FarmMarket"
url_field = "URL"
url_list = []
    for row in cursor:
        url = row[0]
        if url is not None:
            else:
                pass
    print(url)
The image below shows the URLs printed in the Python window.
The URLs printed in the Python window
Article ID: 000033279
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
