HOW TO
List all geoprocessing tools containing specific parameter names in ArcGIS Pro using ArcPy
Last Published: July 4, 2024
Summary
In ArcGIS Pro it is possible to list tools containing specific parameter names. This is ideal for situations when creating programmatically automated tasks using ArcPy, as knowing the exact parameter names is crucial. It is also important during workflow testing as a complete list of parameter names ensures all possible inputs are considered and tested.
Procedure
  1. Open a project in ArcGIS Pro.
  2. Open the Python window. Refer to ArcGIS Pro: Python window for more information.
  3. Run the following script:
    1. Iterate over a list of tools available in ArcGIS.
for tool in arcpy.ListTools("*"):
  1. Retrieve information about the parameters associated with that tool.
    params = arcpy.GetParameterInfo(tool)
  1. Iterate over the list of parameters associated with the current tool and check if the name of the parameter is within the tool. Replace '<parameterName1>' and '<parameterName2>' with the names of the desired parameters. The names of the tools are listed below the print() function.
    for param in params:
      if param.name == "<parameterName1>" or param.name == "<parameterName2>":
            print(tool, param.name)
The code block below demonstrates the full working script.
        if param.name == "output_location" or param.name == "output_name":
The image below shows all the geoprocessing tools containing the specific parameter names in ArcGIS Pro.
All geoprocessing tools are listed
Article ID: 000031510
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
