HOW TO
License ArcGIS Pro on Citrix XenApp and XenDesktop
First Published: September 20, 2019
Summary
ArcGIS Pro can be accessed through Citrix XenApp and Citrix XenDesktop via Concurrent Use Licensing. ArcGIS Pro is designed in such a way that the license level can be changed on a per-user basis through the user interface, which is a departure from the workflow used to change the license level in ArcMap on virtualized environments. In ArcGIS Pro, licensing settings such as the license manager, license level, and licensed extensions, are configured in the user interface and saved in the user's profile. When ArcGIS Pro starts, it uses the settings that were present when last logged off.
Procedure
To change the license level for a user, follow the steps provided in the ArcGIS Pro documentation: Change the license level or extensions
Article ID: 000021924
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
