HOW TO
Launch ArcMap through DOS prompt
Summary
Instructions provided describe how to launch ArcMap in a Windows command or DOS prompt.
Procedure
  1. Start a Windows or DOS prompt by navigating to Start > Programs > Accessories > Command Prompt or Start > Run, type cmd, and click OK.
  2. In the DOS Prompt, type the following and press Enter:
    Code:
    cd C:\Program Files\ArcGIS\Bin
    The above path is the default install location. Enter the appropriate path if ArcGIS Desktop was not installed to the default location.
  3. In the same DOS Prompt window, type the following and press enter:
    Code:
    arcmap.exe
  4. To open an ArcMap document, type arcmap.exe followed by the path and filename of an ArcMap document and press Enter. For example:
    Code:
    arcmap.exe C:\TestData\California.mxd
Article ID: 000008842
Software:
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
